You must type in your text in the letter case you want. For example, if you want to type About Us versus about us, use initial capital letters. Similarly, if you want all caps, type in ABOUT US.
Alternatively, the theme you've selected may have a style that automatically turns all your text into lowercase.
Unless your taking a chance that someone here has one, then we must see the use manual. To do that we must go to Sony.com & enter the Model number in total Please supply as much info as possible.
Model Numbers are usually located on a sticker located on
the back or bottom of the unit. They may also be listed on the product
manual.
Double-check that you are using the model number, not the serial number.
If entering the model, enter the whole model number, dashes are optional (ex: DCR-DVD300 or DCRDVD300).
If selecting your model, try using the Series
filter. A series is a product group that is similar in prefix (ex: SDM
series) or by type (ex: DVD HandycamĀ® Camcorders).
Your Onan engine will do excellent with Mobil One 0w40, Mobile One 5w30.
DO NOT use hydraulic oil in the transmission/transaxle, you will destroy it. Your tractor uses an Eaton 11 Hydrostatic transmission pump with the oil resevour being the cast iron transaxle. The WheelHorse transaxle is as rugged as they come. It uses a solid cast iron housing, case hardened intermediate gears and forged differential gears with an eight pinion differential.
Your transaxle requires 10w40 synthetic or conventional oil as well as a wix 51410 filter or the OEM wheelHorse filter. It should be changed every 100 hours with conventional oil or 250 hours with synthetic. DO NOT use hydraulic oil!
Oil type is 5W40 but you can use 5W30, 3.3 liters with oil filter ( WIX Performance Oil filter WIX 51334 ) Good luck and hope this helps, keep me posted, be glad to help.
The type of oil is SAE 5W30 and your going to need 4.3 liters with the oil filter changed. The filter i use is WIX oil filter and part number is 51036. Good luck and hope this helps.
I'm having the same problem, except mine is not hydrostatic. A 1996 craftman tractor 15.5 briggs 42 ' deck. About to start pulling out my hair!!! Just put on a new drive belt and still no movement.
You need 4,6 qts of 5W-20 motor oil. If I were you I'd start right now to use synthetic oil. If you decide to do it - go with "The First in Synthetics" and the best: Amsoil! 5W-20 XL motor oil gives you (guaranteed) protection for 7.500 miles. (Do not fall for warranty cancellations or similar dealership spam. Magnuson-Moss act prohibts cancellations based on brand). Read this: http://people.msoe.edu/~yoderw/oilfilterstudy/oilfilterstudy.html or this: http://www.lesabret.com/filters/filter.html and try to avoid Fram filters. It seems that any other filter is better than Fram. I'd recommend Amsoil, Wix, Carquest (made by Wix), Mobil...
