The voicemail password is typically set on your PBX or Callmanager. The phone is only a registered extension, when you enter the VM password it is simply passing those digits to your PBX for validation.
Feature 983 log in is 120000 (if 2 digit extension, 1020000 if 3 digit, 10020000 if 4 digit extensions) Select Mbox, enter that locked extensions mail box number, You will see password RESET. Select RESET. Release out. This will reset that mail box password to 0000. Use feature 981 on that phone and enter the new default password of 0000. you will then be prompted to change the password. Feature 985 will show you the extension of the phone you are using.
Hi,If your account is enabled for voice mail, you can receive voice messages in your Inbox and also in a text message on your mobile phone. Both the message in your Inbox and the text message will include a preview of the voice message in text. How do I set up voice mail?
1. Go to https://outlook.com to sign in to your mailbox, go to Options > Voice Mail tab, and then click Set Up Now. 2. When you set up your voice mail: * You'll register your mobile phone number. * Text messaging is set up. You can choose to be notified in a text message that you have voice mail or have missed a call. * Call forwarding is set up so that your mobile provider forwards calls you receive to your voice mail. So if you don't answer your phone, your phone is busy, or you're unreachable or unavailable, the caller will be sent to your voice mail. After your personal greeting is played, the caller can leave a voice message for you. * You can test whether your voice mail has been set up correctly by dialing your mobile phone number from your mobile phone. This verifies that call forwarding is correctly set up with your mobile provider.
How do I change my voice mail after I've set it up?
After you've finished setting up voice mail, you may want to:
* Change the mobile provider's voice mail number so you can use the key your provider has reserved for accessing voice mail to access your voice mail. For details about how to do this, see Changing the Number You Call to Access Your Voice Mail. * Create a contact on your mobile phone. For details about how to do this, see Create a Contact for Voice Mail. * Assign a speed dial key to the contact you create for Outlook Web App voice mail. For details about how to do this, see Set Up Speed Dialing for Voice Mail.
What else do I need to know?
* The voice mail service is available only to certain customers in certain regions. If you can use voice mail, you'll see a welcome message in your Inbox telling you how to set up voice mail for your account.
have you tried calling your voicemail inbox and deleting it there? normaly a voice mail is not saved on your phone, but at your provider. so you have to call your mailbox as if you want to listen to your voicemails, and there you can choose to hear, to save or to delete it.
You have to dial 1 to get in your mail box. Follow prompts to listen to your messages. If you never activated your voicemail your password is most likely the last 4 digits of your cell phone number. Delete messages and your mail box will be able to take new voice mail. Worse case scenario, go to your nearest store and ask a representative to reset your password to clear the messages.
I received a voice mail which seemed to correct the problem. Sort of the same solution as when an actual extension is displayed. (you connect/disconnect)
Go back to your vendor and get the password for mailbox 999 and the instructions to log into it.
The mailbox exists or it wouldn't ask for a password (they're assigned by default), so you need to go to mailbox 999 and chose option 6 1 3 which is mailbox administration reset password. That will clear the password and you can log into the voice mail automatically from the extension by dialing the voice mail access code.
