KitchenAid KSM5PS Heavy Duty Stand Mixer Logo
Chris Pickul Posted on Feb 06, 2010
Kitchenaid Heavy Duty 325 stand mixer. Making cookies and now the motor runs but it doesn't turn to mix. PLease help/.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 07, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
581
Points
KITCHEN AID ARTISAN 325 WATTS TILTING HEAD PIN CAME OF WHILE MIXING DOUGH. HOW IS THE EASIEST WAY TO INERT PIN BACK OR LINE UP THE HOLES TO INSERT PIN?.
FRANKAMOR
How can I adjust bowl depth?
KitchenAid K5SS Heavy Duty Commercial Stand Mixer ...
www.fixya.com/...kitchenaid...k5ss_heavy_duty/adjust_beater_height
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust beater height related issues. Get free ... Beater hits bowl beater height adjustment screw does not fix problem ... beater ... ...adjust beater depth-it is scraping the bottom of the bowl.
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Adjust
www.fixya.com/search/p105880-kitchenaid...k5ss_heavy_duty/adjust
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust related issues. Get free help ... How can I adjust beater to bowl clearance on my Kitchenaid mixer? I have a kitchen ... How do I adjust the depth of the dough hook. how do I adjust ...
How To Adjust the Bowl Height of Your Stand Mixer ' The ...
www.thekitchn.com/how-to-adjust-the-...
Apartment Therapy's The KitchnFeb 10, 2011 - In the world of stand mixers, there's two different types. ... It's easier than you think and will make your appliance last longer and food taste better! ... If yourbowl height is too high, you'll hear the adjustment needing to be made before you ... I have a different issue with my KitchenAid Artisan mixer (tilt head).
Kitchenaid stand mixer 5SSWH 325 watts. How do I adjust the bowl height? Beater is too far from bottom of bowl. Thanks! Cas
There is a screw at the bottom of the motor head (flat head) you usually can't see it because of the top rim of the mixing bowl. hard to see and hard to reach, it may also be hard to turn due to "gunk" from mixing stuff (egg butter flour sugar) turn the screw counter clockwise to lower the motor head clockwise to raise it, you may also have the wrong size beater, it is not an uncommon problem, if you are the original owner and you have the original beater it should fix your problem with the adjusting screw, however I am not clear as to your model a 5SSWH would actually be a K5SSWH, which stands for kitchenaid 5 quart solid state white mixer, if this is your model number and you have the correct beater size then the adjusting screw will work to lower the head down, adjust it down using the stir or slowest speed just untill you can hear the beater "Ding" against the bottom of the bowl, then back it off a quarter turn to adjust properly. Hope this helps, let us know
325 k5ss mixer stir speed not working, but works in all other gears
First congrats on the great mixer that you have. next the pro 6 or professional 600 series mixers are of an entirely different design than the one that you have even though they are both bowl lift. Do you really need 6 quarts capacity? The pro series is a 575 watt mixer BTW, and it will have more power available to you IF you are doing bread or a lot of food grinding, if that is a requirement that you have then the 6 / 600 series is the better suited mixer but if all you are doing is general medium to light mixing duties then fix and keep the K5SS it a great machine,
Kitchen aid stand mixer blades do not reach bottom of bowl
go to youtube type in ajustment on kitchen aids and it will show u step by step hope this helps
2helpful
Bread dough hook slips when mixing
This is not a solution but I think you have a serious problem you might have sheared some gear teeth whent the mixer jammed and it only manifests itself under a heavy load, I would take it to a repair guy, those mixers are expensive and it would be worth it.
Kitchenaid mixer 45ss
I dont know much about them but If you cannot get it repaired I do have a lift bowl stand mixer that I bought without the bowl or attachments that I would sell for $80.00 Or I will buy your attachments. Thanks, Mark.
2helpful
Kitchen Aid Mixer has a sound but it doesn't have power to mix
Hi. Goto www.mendingshed.com and download the free Kitchenaid Service Manual.
You may have overloaded the mixer with bread or cookie dough, causing internal damage to the gears.
If you plan to do the repair yourself, you might also consider removing the old grease and oil. Remove, clean and regrease the planetary gear assembly as well. This will add years of life to your mixer.
Regrease with Chevron FM ALC EP-2 product.
If this solution has assisted you, please rate it. Good luck! ricardok45
KitchenAid 325 Heavy Duty Stand Mixer runs with low power & clicking noise
well there is a couple of things to try
1. see if kitchenaid sells the motor or
2. if a local appliance parts store can get the motor
this is the only thing you can do about the motor , the wires in the motor are shot and it will need reconstructing in the wireing, that is why it won't run fast and strong , because the wires have been heated up to much and now they can't create a strong enough magnetic field
but to replace the motor shouldn't be to hard just a little patience
if you need any more help just let me know!
electech
MIxer quit working while mixing 3 batches of oatmeal cookies
Hi. Kitchenaid's warranty is 1 year.
Most likely, the plastic transmission housing has failed, causing damage to the working parts inside your mixer. Take it to a local repair place and have them work up a quote to repair it. It will take at least a month to get the parts.
If this solution has assisted you, please rate it. ricardok45
I
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
