Normally there are two reasons for the given problem.
1). Bad or defective CCD. and/or
2). shutter not working.
in
the first case the only solution is the replacement of the CCD.
Please click HERE
And in
the later case sticking of shutter blade, non functioning of shutter
blade will cause the problem. This can be rectified by sending it to
some repairer.
Click HERE for the manual.
Main support number: 800-755-3854
I hope you are satisfied with my solution..
Goodluck..
Alright please give this a try before you go for the repair:
1. Hold camera firmly in left hand.
2. Smartly rap front of camera with knuckles of right hand on the "Fuji finepix" logo.
This trick helped most of them.I hope this will help you also.r. You can also Try this;turn camera on,squeeze case between your fingers,where
Fuji logo is,if ribbon is just loose the lcd should come back on. If
this doesn't work,take it to a local camera shop and have them fix
it,it's a very simple fix.
Goodluck..
Thanks for your advice, but the CCD problem described in the link isn't the same as mine. My screen is totally white and photos and other information are properly displayed.
Also, there is no indication that Lumix cameras are affected by the problem described in the CCD link.
The manual you link is for Pentax, not Lumix, so it's not applicable.
Can someone provide information about Lumix problems.
Thanks.
