"F27" is an Overflow Condition error. The following link explains how to troubleshoot:
http://www.fixya.com/support/r3608602-f27_error_code
This can be one of the more difficult error codes to diagnose because there are so many potential causes. Read through the information provided and try to eliminate the easy (and obvious) things first. If you have any questions, please let me know. I hope this help you.
HINT: One obvious symptom that helps narrow down a potential cause is the fact that the washer does not stop filling with water even when unplugged. More than likely, you have a defective water inlet valve that is causing this.
Close the washer and press the START/PAUSE/Cancel
button to remove error displayed and restart the cycle. If it doesn't work, it means that
the valve at the water entry needs to be replaced..
Hope this helps..
