SOURCE: philippe starck with fossil ph-2006
Fossil Contact Information
Main support number 1-800-842-8621
Email support [email protected]
hope this helps
SOURCE: How to adjust the watch strap
I just bought the o-ring watch by Starck, and it looks to have the same style of strap. If you look on the side of the clasp, you will see a pin on both ends. You have to remove these retention pins first (which may require tools that are unavailable to you). First, stabilize the watch on its side on a soft mat - I used the back of a mouse pad. Then, use a thin, stiff piece of metal tool to push the pins out slightly. I used a crafting tool. Once the pin sticks out enough, you can use a fine set of pliers to pull them the rest of the way out. (If this does not make much sense at this point, you may be best off going to watch shop.) Once you remove the pins, the clasp can be removed from the strap simply by lifting the clamp. You then trim the strap with a pair of sharp scissors to the appropriate length - make sure you see exactly what the end looks like, because the shortened strap will need to have the same apperance. After trimming, reclamp the clasp onto the strap, and reinsert the pin. You may need a small hammer to get the pins seated completely. Then, you're done. So obviously intuitive, why would anyone need directions, right? Honestly, Fossil did not make this one easy at all. Kind of irritating.
SOURCE: Setting time & date on Philippe Starck Fossile watch ph1080
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
SOURCE: Strap for Fossil Philippe Starck PH1035 Wrist Watch
Type in your browser FOSSIL WATCHES.
You will find numerous sites. Go thru them till you find what you're looking for.
