How do I remove the stand on a conia LCD screen to mount the TV on the wall
The TV will mount to the wall via the VESA screw mounts on the back of the LCD. If it is a smaller, monitor sized LCD then the screw pattern will be either 75x75mm or 100x100mm. On larger TVs is it usually 100x200mm. Sometimes the base is screwed into this mount and othertimes to the bottom. Simply unscrew it from the screen. Be sure that the wall mounting kit can handle your LCDs VESA screw pattern, screen size and screen weight.
