Kodak EasyShare C613 Digital Camera Logo
Posted on Feb 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lens error Every time I want to zoom in on a picture, it says "lens error 41,1,1,79" But it zooms in when I'm on video.
Anonymous
Level 3:
  • Master 6,831 Answers
  • Posted on Sep 30, 2010
Anonymous
Master
Level 3:
Answers
6831
Questions
0
Helped
1215802
Points
16135
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Pania Lee
Level 3:
Genius:
  • Kodak Master 1,099 Answers
  • Posted on Feb 10, 2010
Pania Lee
Kodak Master
Level 3:
Genius:
Answers
1099
Questions
Helped
219184
Points
1986
Please also try to upload new firmware: I doubt that it will solve the issue, but the alternative is a repair.
Connect the camera with the computer.
Turn the camera on.
Click onto the link and follow the instructions.
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=10732/10810&product=EKN032918
Fujifilm finepix j38 series reads zoom error and wont take a pic.
If you have some skills, you can open the camera and cline your zoom lens with toothbrush and compressed air. Try to separate zoom lens from the electric motor. usually is 2 or 3 screws. You will see a lot of sand inside the camera and lens. And next time when you will go to the beach, you will take more care about your camera.
Solution 2, and more easy is to buy another zoom lens from ebay.Or another camera same model with broken LCD or other technical problem than zoom lens.
Zoom error
It sounds as though your lens is sticking while trying to extend. Check the lens to see if it binds. Also look at the retracted lens and see if the center portion is properly centered or is cocked to one side and out of alignment.
Once your camera is working properly, as you say it does at times, hold the camera with the lens pointed downward and run the zoom in and out several times to see if there is dirt caught between the lens cylinders. Sometimes that will work any debris out.
Hi, my zoom is stuck out and won't retract.
Your lens motor is most likely burnt out. The only way to continue taking pictures is push the lens in manually, You may have problems with the focus after doing this, so just turn the lens manually until you are zoomed in properly. If you have a warranty now is the time to use it.
Problems after repairing a Lens-error (E18) on a PowerShot A530
I think that the lens system is in different groups, which move independently based on a cam system. (This is based on watching the lens move while running the zoom lever.) I would suspect that your "cam timing" is not set quite right. You can either try to correct it by trial-and-error, making only small changes at a time, or send it in for factory calibration.
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
2answers
Zoom Error
Lens unit has to come out to see whether the problem can be sorted out without spares going in. But unfortunately you have to go from the back on this model which means disconnecting and removing all 3 pc boards and the LCD screen and then loosening the lens mounting to slide the lens out from the back. You may have to dismantle the free lens further once it is out to see exactly what the damage is ( if any ).
2answers
Zoom error message
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
3answers
Focusing the 770
Tom, It's best to do the zoom first, then focus (if you are using the autofocus).
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
