I have a 36in DCS range: my broiler does not ignite(lights up)no flame. Tried cleaning around it,nothing seems to work. Do I need a replacement part? If so who would look at it? It is 9 years old. Is it worth fixing? Please help!
Re: I have a 36in DCS range: my broiler does not...
Most likely it needs a new hot surface ignitor, which is normal wear and tear. Can cost you around $200-400, depending on where you live. DCS oven appliance repair in orange county, ca
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
You don't say if it lights up! If it lights up and stays on low it's the thermostat that's at fault, they are not adjustable and will need to be replaced.
You didn't state whether you used a DCS conversion kit or not. I was able to find conversion instructions for a model similar to yours (not an exact match) but it will give you an idea as to what all is involved. DCS RGSC 305 Instructions Manual
There is an easy way to relight a pilot light in an oven/broiler if you do not have long fireplace matches and you are scared to stick your arm in with a regular lighter: Light a long stick of incense, but do not blow out the flame. Open the broiler door. Turn the oven to "broil" and extend the lit incense stick in \to the back of the broiler space. Wave the incense stick slowly back and forth below the broiler coil towards the rear of the oven until you hear the pilot light ignite, then pull the incense stick out, blow out the flame and insert into an incense holder.
