Need value for part R14109
R14109=750ohms 5% 1/4w
(Resistor(750r5%.25W/R14109/179317)
There is much more likely wrong with the TV. Resistor don't normally burn out with help, say, without a failing flyback transformer and possibly taking a transistor or two with it.
If you need the manual, go to
http://www.samswebsite.com/photofact/pf_search.asp
and type in "F31317" into the search field, you will several listings.
If you decide to replace it yourself, here's some more part numbers in case you need them.
Model: RCA\F25422TX41
Symptom: Dead
Necessary parts: Transistor(Q14401)
Main Voltage regulator Q14101
Resistor R14109 open.
Research indicated the flyback transformer most probably bad
\\CTC203AC4\HOT/D2578(Q14101/242224)*
Flyback(14536119A/T14401/244229)*
Main reg(P9NBSO/Q14101/244223)
\Reg(MPS8599/Q14102/147665)
Reg(MPSA06/Q14103/232218)
Hope this helps you.
ZT3000
"Beta tester of "0"s and "1's"
