HP PSC 1210 All-In-One InkJet Printer Logo
Posted on Feb 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The pop up box that says out of paper keeps popping up even though there is paper
Anonymous
Level 2:
  • Expert 71 Answers
  • Posted on Feb 09, 2010
Anonymous
Expert
Level 2:
Answers
71
Questions
0
Helped
12778
Points
148
Sir check the paper sensor of the printer
Filter in the ball keeps popping out even though it is clipped in place.
Air filter is not getting air flow.air must pass thru filter or it will pop off.I placed filter against exhaust end of shop-vac ( NOT SUCTION END) untill I got air coming out.
Canon pixma ip4600 says it cant print bc theres not paper, but there is. i cant figure out how to print.
Many times the switch that lets the printer know it's out of paper is stuck in position, or dust has clogged it. If you can blow the small bits of paper or dust out you can get it going again. I use a can of compressed air to clean my printer about once a month to stop this from happening. It is a common problem.
Once i have found all players and the match connects only me and another player are playing even though all 10 players are found this keeps happening!!! help?!??!?
This is probably a connection issue. Check to see if your NAT settings are secure, to do this go to your dashboard, go to settings, then check network. Check it to x-box live. If nothing pops up, then your NAT is open. If it's Closed or Secure, then a notice will pop up telling you that it is closed and some tips on how to open it.
2helpful
Water keeps popping off t he detergent cap.. even though water is not even hook up.. guess it is detergent popping out .. what is wrong with it.. cleaning fitting is not even on
detergent non return valve stuck, allowing water to back feed into the chemical tank.
depends on what machine it is as to where the non return valve is.
2helpful
DELL DIMENSION 3100 PROBLEM
Even the best pop-up blocker may let a few through. If you are getting more than a few (especially if they are occurring when you are not actively browsing the web), I would highly recommend downloading, installing, and scanning with a free program called SpyBot Search & Destroy. This will remove any spyware/adware that might be causing your added pop-ups.
1helpful
3answers
Pixma 4200 compatible ink cartridge problem help
The ink detection is a critical function of the printer.
Ink actually acts as a lubricant for the heads, and running (Printing) without ink is equavalent to driving a car without oil.
I.E. It will seize eventually....
Hopefully you didn't print much without the ink, and your heads are still in good shape...
Here is a chip reset procedure....
With the original chip now attached to the compatible cartridge (you may need double sided tape to get the chip to stick well to the cartridge), and with the cartridge now in the printer, Press and hold the Reset/OK Button for 5 seconds to reset the chips.
  1. The "Ink Low" dialog box will pop up (similar to photo 1 below)
  2. Continue to print until the "ink has run out" dialog box pops up (similar to photo 2 Below) Click "OK" to continue to print.
  3. The "Ink Low" dialog box may reappear, if so repeat the first 2 steps
  4. Then the "once empty" dialog box will pop up (similar to photo 3 Below) Click "Yes" to continue to print
  5. The "Not Liable" dialog box will pop up (similar to photo 4 below). Click "Yes" to continue to print
  6. Continue to print until the "remaining level of ink" dialog box pops up (similar to photo 5 Below) Click "OK" to continue to print
  7. Another dialog box will pop up with the "press and hold the Resume" or "press and hold the Paper Feed" button (similar to photo 6). Press and hold the "STOP/RESET" button (for Canon MP Series) or "PAPER FEED" button (for Canon IP Series) for 5 seconds. DO NOT Click "Back" or "Cancel Printing"
  8. The "Ink Monitor" dialog box will appear and the printer will continue to print. (similar to photo 7) In the event that that the "press and hold the Resume " dialog box pops up again, Press and hold the Paper Feed Button or Stop/Reset Button for 5 seconds
k24674
Grand Canyon Tech
Grand Canyon Tech
