I have installed a Zebra LP2844 label printer onto my computer with windows vista. No matter what quantity of copies I select, the printer only prints one copy.
Is the printer set for label taken, if it is then it is waiting for the sensor to see the label is gone before printing the next one. Apart from that, check the settings in the driver and make sure it is all set correctly
To send text to printer in dos command you should first install a driver from www.seagullscientific.com
then in the properties you can use send file to printer.
To send the files from command :
Check if the program ssdal.exe has been correctly installed.
to have help use ssdel help send at dos prompt
to send the file
ssdal send filename printername should do the trick
hope it helps
reinstall it again the printer driver, then test if it appear rubbish on windows test print but good on paper labels itself your gonna use, then use it. it doesnt matter at all as long as it's print good ok on actual paper application
Welcome to the club. Been fighting this for almost a year. There is now a driver for vista available from Zebra to fix. I can now print 1 label from quick books. to print a second i have to restart computer and quick books. still searching for the answer.
Make sure the label size is set correctly and the printer is calibrated. If this doesn't work download drivers from Nice Lable or Seagul Scientific websites to suit you Printer, these are more adjustable than the original Zebra drivers and handle small labels better.
Same here... Can't be the printer - has to be something with either the paypal software or the driver since my 'SAMPLE' prints solid as well. Did you ever find a solution?
possibly not a real LP2844 but an LP2543, a printer mass produced for and used by UPS. refurbishers change the label and sell as LP2844 because they are almost identical.
if it has an AC-AC adapter, it is an LP2543. LP2844 uses a AC-DC adapter, and all LP2844's have USB ports.
