Connection Problem Device: SMC-WEBT-G Quantity: 9 pcs FLOOR : 3 floor Connection: Installed One CABLE each floor which is connected to on SMCWEBT-G and the 2 access point is bridge or repeater to the main SMCWEBT-G
NOW, my problem is... everytime im going to connect the 1st floor connector to switch... IT STOPS THE CONNECTION. IP configuration is GOOD... Mac address of MAIN is copied to 2 accesspoint and 2 accesspoint mac is entered to main smcwebt-g MODE: configured as Repeater each Device
Why is it stop or hangs the connectivity if i am going to connect the 2nd floor the the switch same as the 3rd floor? Any advise or any solution for my configuration? thanks in advance....
Do you leave the router switched on all the time? If not then this can be your problem as some routers can take up to 3 days to get full signal strength and keep it. When switching the router off and powering back up it has to search for the signal again. It will happen whether you are wireless or cable. If you are wireless and router is always on it may be where it is located, walls can interfere with the signals so try moving it to another area to see if that helps.
Have you tried removing the card and reinserting it? Sometimes when the pc isn't properly recognizing a device it just needs to be reattached. Also try rebooting the pc. The device shouldn't be conflicting since all xp and later pcs have irq steering.
For you to be able to do that, you will need to set the SMC router to bridge mode, you will not be able to do that by yourself because only tech from your ISP have the capability of doing that since they have this tool that can operate on the router setting it to bridgemode. Basically, you will need to call your ISP to set the router to bridgemode and from there, you will be able to configure the linksys router.
Hope this information will help.
Your response is very much appreciated. Thank you for using FixYa!
I'm unsure of the exact part number here but using the model number I checked the manual. This looks like it's just an access point which extends a current network you have. If you only have your laptop, this device and your internet modem it may not give you the wireless connectivity you're looking for. On a normal setup you would plug your modem into a router, plug your laptop into the router and set it up with all your DSL/Cable connection information as well as wireless on/off. You can then unplug from the router and continue life. with this one it's only connecting to an existing setup (another router or another wireless network) and extending it.
If you are looking for a solution to give you a router that connects to your modem and gives you wireless or adding multiple devices on a single connection I would recommend returning this and getting an all-in-one router such as this: http://homestore.cisco.com/en-us/Routers/Linksys-E1000-Wirelessn-router_stcVVproductId97826160VVcatId551966VVviewprod.htm?icid=linksys-specs-e1000-learnmore-btn&src2=linksys-specs-e1000-learnmore-btn
Consdier first that both devices are NAT firewalls and your ISP probably only allows one address. So you would need to put one behind the other. This may not work like you plan. PCs behind the second will not be seen on the LAN by PCs on the first.
The N1 is a very good router. Consider relocting it to a more central location.
Another trick is to locate it near a central wall if it is block. By adding 1 remote antenna and drilling through that wall witha short antenna cable you can get much better coverage on the other side.
It could also be an ethernet problm 1. Power down SMC, plug WAN of SMC to LAN of router and power up SMC. If both devices show link lights and activity the hardware is OK. If not you need a "crossover" cable.
It appears the SMC router is faulty. The router is getting an IP address from the IPS because they can can PING your router and get a reply BUT the router's PPoE/DSL light is not on, it means it is not connecting with the ISP's WEB server and therefore you cannot get into the Internet.
It may because you have a mac filter on. If so you can correct this by connecting to the router then in a Internet explorer type 192.168.1.1 and you should have a configure screen available then either disable the mac filter or enter the other mac adresses. Good Luck
With a HomeLink card installed in your PC, connect your PC to a phone jack using a standard phone cable. Using another standard phone cable, connect the card's other phone cable port to connect to your second PC. Continue to connect up to twenty-five PCs in this way on one chain. If you want to use your telephone, modem, or fax machine, add a two-way splitter to your wall?s phone jack or connect the device to the empty phone jack in the last card at the end of your daisy chain.
Daisy-chaining your HomeLink PCs and peripherals can create a simple network that acts in the same way an Ethernet network acts on your PC's desktop. In a HomeLink network, data passes into one side of a port, and continues out from the port?s other side. You can string up to 25 PCs on a single HomeLink network, provided that the entire length of cable does not exceed 150 meters (500 feet).
HomeLink networks can send data through existing telephone lines without disrupting your telephone service. If you have PCs on two different floors of your house, plug one of the downstairs PCs into the phone jack in the wall, and you're able to network your PCs upstairs without running excessive amounts of extra cable.
Update only the firmware.......
