I get the following error when trying to print checks in Quickbooks Premier 2004: The printer driver you are using does not support a full range of fonts for this print out.
1) Are you able to use the printer outside of QuickBooks?
2) Have you checked to make sure QuickBooks is set to use the same printer as your "windows default" printer?
a) In QB, go to "File" then "Printer Setup"
b) Then select "Checks" and review the printer selected, confirm that the default printer in quickbooks, matches the "windows" default printer
3) Are you using a different printer (other than the windows default printer)? such as a special printer with MICR ink?
Then you may need to reinstall the printer.
The printer is used as the default printer. I get this error only with Quickbooks. It works just fine with other software.
