The front struts for a 2005 Dodge Neon are $66.99 each from Autozone. The part number is G55892 and they show as a stock item.--------------------------------------------------------------------------------- Programmateur De Calculateur
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
If it were me, I'd cut off the connectors and switch them, but I solder things every day. I don't think they make any adapter wiring harness for this problem.
ok, this is a good un!
have you ever stoped to think your old starter may have had nothing wrong with it in the first place?????
it could be a simpel brake in the wireing loom,,,,
i bet that one hurt "A"!
hook up a 12 volt light bulb to the small wire that go's to the starter and ground it to the car engine get a pall to turn the kye to start poshion and hold it there the 12 volt bulb should light up and stay lit if the kye is held over now give the wire harnes a good poke about to see if the light go's out? if it dose, fine the brake in the loom and fix it!
if its a new amp there should be a problem. make sure you have your remote wire hooked up to your radio(its blue). make sure your fuse on your amp wire isnt blow and make sure you have a good ground. if your runnin the ground off the car make sure the paint is scratched off that area
