Computers & Internet Logo
Posted on Feb 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My plug in mouse for my hp laptop isnt working the red light wont come on and its plugged in
Anonymous
Level 3:
Genius:
  • Master 1,288 Answers
  • Posted on Feb 10, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1288
Questions
Helped
286027
Points
4123
First of all boot to the Bios, think its F2 or Del key on that model..
In the advanced screen, checdk to see that USB controllers are enabled for the mouse.
If they are, try plugging another usb peripheral (usb drive or dongle) into the ports, if they ARE recognised, then issue is with the mouse. If they do not register, then issue is with the USB ports. Possibly a damaged USB controller
keithborn196
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
keithborn196
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
0
Helped
2312
Points
21
Goto control panel select mice ect check that the mice is activated you might have to go into bios to enable usb mouse if formentioned dose not work
3answers
HP optical Mouse not working
Okay turn it over is there a light, if not unplug it and after a while plug it back in. If you don`t get a light on the bottom try a differnet pc to find out if the problem is your pc or your mouse.
My microsoft optical mouse isnt working on my lap top the red light is not working anymore so i cant get on my laptop so how do i fix it?
Replace worn out batteries in it. If that isnt the problem then access the BIOS screen by booting laptop up and pressing DEL key, search for setting that lists infra red laptop pad, enable and save / /reboot.
I plug in my mouse to my laptop and it wont work, the bottem doesnt even turn red.. when i connect it all it says is usb device not recognized, it worked last night and tonight its not.
Try disconnecting the mouse from the usb port and reboot the unit.
Now, on your touch pad, top left blue led is let showing it is functioning. Press the center button next to the led, which will shut off the internal mouse.
Plug in your mouse to a different USB port and the unit should see the mouse.
If not and the mouse does not light up, replace the mouse.
You may have had a conflict with the internal and external mouse.
I have a new HP Pavilion laptop and a new Belkin wireless mouse. I have plugged in the driver and the red light is on. I have also turned on the mouse. The mouse will not move the cursor. What is wrong?...
Did you press the reset button on the bottom or inside the mouse. That resets the mouse to the usb wireless you plugged in. And, make sure the batteries are good and orientated correctly in the mouse.
2helpful
2answers
Belkin wireless travel mouse not connecting to Mac
If you have a usb extension cable try plugging it in so you can place it on a firm surface when you press the sync buttons. Have heard of some issues with activating both mouse and fob buttons at once because of difficulty in reaching the fobs sync button.
Hp wireless mouse not working
u still need the remote that plugs into the wall
if you have it it needs to be nearby like close
1helpful
My keyboard and touch pad isnt working on my laptop. i plugged a mouse in my usb and its moving.. but my keypad isnt working... my caps lock is lit up..i tried pressing it to turn it off but it didnt...
If your operating system is Xp / vista reimage your unit by hit F11 on started up & Hp splash screen - select advanced - select full destructive recovery - you have corrupted your device controler for human interface devices - like your k/board & mouse - there is no way to reinstall the required dll's so full recovery is required.
Audio Problems
see if the drivers are loaded correctlly, uninstall the audio device and scan for hardware change, see if installs properlly next time
I can't get it to work
try back ports might have bad unit plug on the mouse bad
Grand Canyon Tech
Grand Canyon Tech
