WASHER IS ABOUT 10 YRS OLD.I HAVE NEVER HAD PROBLEMS WITH IT BEFORE. MY WASHER FILLED UP WITH WATER THEN NOTHING ELSE OCCURED,NO AGITATION .NO SPIN ,NOTHING ,THEN IT STARTED TO MAKE A VERY ODD NOISE A METALLIAC GRIND NOISE.
I have a Kenmore 80 series model 110.20892.996. I just put the clothes in the machine started going then it got to the part where it is supposed to drain the water before the spin and all you can smell is burning plastic smell. It just stoped so now the machine is full of water and the smell of burning plastic is all over the house ...helpHi,
You can't post conmments that contain an email address.
Possible bad pressure switch. Turn unit on and jump out 2 wires at a time (3 wires go to it). See if any of your combinations get unit running (one of them will cause water valve to open); if so then that is your problem. Thanks, please leave feedback or contact me again for more info if you need it.
if your washer will agitate when set to fill but not fill, then your pressure switch is bad. also you may want to check and see if you are getting both hot and cold to your washer.
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
Your agitator may be fine but how is your washer behaving is it trying to perform two acctions at one time like spinning and agitating at one time the tarnmission may be locked up
