CF60 indicates Recycle Toner Transport area lock. U need to take out the process unit, remove developer unit, remove drum, drum blade & recovery blade, disposed all waste toner, make sure the gear can turn properly. Then reassembly back everything.
It cannot be done without the dongle. But u can try the trial period, once the trial period is almost reach, u can try update the machine firmware. But not sure whether it can work or not...
Check to make sure that the recycled toner auger is able to turn. This is located on the front side of your process unit and takes used toner and dumps it back in the developer unit. If not check to make sure all of your gears are not stripped.
Hi
