Printer error. Try to turn the printer on again after turning off the power and waiting 3 seconds. If a service error is displayed even with the printer turned off and then on again, turn off the printer and contact the service representative where you purchased the printer. When contacting the service representative, inform them of the error code displayed and symptoms.
Error Code: E000
SOURCE: Fixing unit error. Turn off and
The problem is in your fixing unit
the reasons may be
(i)The thermistor has an open circuit or a short circuit.
(ii) he heater has an open circuit.The thermal fuse has blown.
(iii)The power supply PCB has a fault.
(iv)The engine controller PCB has a fault.
Check the following,
- Check the connector of the fixing film unit.If found no problems,
-Replace the fixing film unit.Not solved?
- Replace the power supply PCB.Still having problem?
- Replace the engine controller PCB.
and that's it
