PHONE UNLOCK PROCEDURE
Please follow the instructions below to unlock your LG KG800 handset:
1. Insert a Vodafone Australia working SIM card.
2. Ensure the phone is charged and then switch the phone on.
3. Enter 2945#*7101# while in standby mode
4. Select Menu, then go to Settings > Security > SIM Lock > Network
5. Select Deactivate and enter the 8-digit NCK unlocking code provide for your handset..
6. The handset will be unlocked automatically and will display "Done".
I found this note at at forum; see can you check if result is ok?
How to Unlock LG KG800 Chocolate Without a Code (not reliable):
1:Insert SIM from the network that it is locked to.
2:Turn on phone.
3:On home Screen, slide up phone.
4:Type 2945#*#
5:ENG. Mode menu should appear.
6:Go Down to Factory Reset. Select it. May take a few minutes to reset!
7:This will reset the phone back to before the phone was locked to a network.
8:The phone will automatically restart (the network logo at start up will not change).
9:Now insert any SIM card and the phone should turn on normally
10:The phone is now unlocked and you can customize the setting as you like
This way seems cheaper
http://www.uniquephones.com/LG-KG800%20(...
Reply a comment.
