Disconnect the washer from the power source. Use a putty knife blade to release the locks of the top panel. Insert the putty knife blade in the seam between the top panel and the front panel about 2 3/4" from the edges. Push until the locks are released and lift the top panel.
Open the door and remove the 2 screws from the bottom of the door opening. Remove the 2 screws from the upper side of the front panel and pull the front panel out. Disconnect the door switch connector and remove the front panel completely.
