Maytag Neptune dryer mdg40000bwq - no heat. how do i pinpoint the issue
If lil heat or takes a long time check ur venting.
if no heat on a gas dryer u must check the ignitor for any damages, the thermal fuse for continuity with a meter, and most have gas secondary coils which could be defective. those would prevent a gas dryer from heating.. hope this helps let me know whut u found
Check the thermal fuse in back.
The burner is not lighting right...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
