Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Posted on Feb 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool Ultimate Care Heavy Duty Super Capacity Plus
Spins only when it gets a "boost" aka - when I give the tub some hand-aided inertia. Doesnt' have the torque to kick in and spin the wet heavy clothes on it's own. Engine -good. Pump - fine. Coupler - good.
What's left clutch and tranny? Assuming tranny to be ok - since it agitates just fine... Clutch? I'm I right?
Anonymous
Level 3:
  • Master 572 Answers
  • Posted on Feb 12, 2010
Anonymous
Master
Level 3:
Answers
572
Questions
0
Helped
134371
Points
1612
Clutch could be it check if nothing is jammed between tub andbasket. if u have an oily tranny i would replace it
My whirlpool ultimate Care II Heavy Duty Super Capacity Plus washer Very slightly agitates and don't spin dry
The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
Little AGITATION clothes not getting clean, Spin cycle is fine
Hi Sherrie,
There is a service manual located inside the front left side of the cabinet.I find it easier to turn the washer on it's back and then reach up in the cabinet to get it.Hope this Helps !
1helpful
Ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
Ultimate care heavy duty dryer is not heating
SOUNDS LIKE YOVE GOT A CLO OF LENT IN THE LINT BASKET CLEAN AND LET ME KNOW HOW IT TURNS OUT
May 03, 2009 • Dryers
5helpful
Won't spin or agitate
coupling.between motor and gearcase.
Whirlpool Wash Machine
go to repair clinic .com and look up you model and it will show you pictures of what your looking for
10helpful
2answers
Agitator
if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
