I want to know step by step how i can transfer my pics from cell phone to my computer. how do i get a online album dont understand want to save pictures from my phone to my computer
Re: how do i get online album and be able to transfer
Use USB device from your cellphone to PC. Attach the usb to your cellphone and as the pc turns on plug the usb in your computer . Windows will automatically detects your cellphone. In your control panel open the cellphone drive and click and drag the files you want to transfer to your PC.
Transfer them to a computer first and put them in a single file and ID that file, then download them to the flash drive. I know of no other way, sorry.
Not sure if you meant photo album or music album??? Here is the steps for both, music first:
Transfer music from a computer You can use the following methods to transfer music: ● To install Nokia Music to manage and organise your music files, download the PC software from www.music.nokia.com/download, and follow the instructions. ● To view your device on a computer as a mass memory device where you can transfer any data files, make the connection with a compatible USB data cable or Bluetooth connectivity. If you are using a USB data cable, select Mass storage as the connection mode. ● To synchronise music with Windows Media Player, connect a compatible USB data cable, and select Media transfer as the connection mode. To change the default USB connection mode, select Menu > Settings and Connectivity > USB > USB connection mode.
This works for music, photos, or video: Select Menu > Settings and Connectivity > USB. To have the device ask the purpose of the connection each time a compatible data cable is connected, select Ask on connection > Yes. If the Ask on connection option is turned off or you want to change the mode during an active connection, select USB connection mode and from the following: ● PC Suite — Use Nokia PC applications such as Nokia Ovi Suite, and Nokia Software Updater. ● Mass storage — Transfer data between your device and a compatible PC. ● Image transfer — Print images with a compatible printer. ● Media transfer — Synchronise music with Nokia Music or Windows Media Player.
Here is the link for your manual online: http://nds1.nokia.com/phones/files/guides/Nokia_N97-1_UG_en.pdf
Hello there,
Step 1. If your phone has a data cable, please connect your phone via data cable to your computer. Then copy your pic to your pc, you can then transfer it into your memory card.
Step 2. If step 1. does not work then go over to the picture on your phone. Select the option, scroll to 'organise", this would drop down options of "copy to phone memory" and "move to phone memory". The former would leave a copy on the original directory while the latter would move to a now location (memory card).
Kind regards
by bluetooth you can send pictures to the computer! for that you want to install bluetooth cd! to the computer! then pair the device! then you send pic to pc
you have to download a software for your phone. just go their website. www.lgmobile.com then select UK country. then click on SUPPORT link you'll see on the left side manual & software, just click on it and search for your unit then download the software. you can now upload your pictures. music from your phone to pc or vice versa. hope this help you.
xtinz
Checklist
1. did you have a lock on your pictures?
2. did you transfer your pictures to your phone memory? (They are first stored In camera, you then manually move to the phone)
this is a solution for those who have not moved the pictures to the phone memory yet (ie it is still in camera) pictures in phone memory cannot be uploaded..
Step 1. start the camera by pressing the ok button at the center. (alternative is through the menu. left soft key. then pressing 4)
Step 2. if you have a user lock. input it now. if you did not have one then you should be on the pictures menu
notes
i) the lock is the last 4 digits of your phone by default. (if you had used the lock pictures option)
ii) if you had swapped your phone like i did and later return your cellular service to it, do not use your custom lock, rather, use the default lock ie last digits of phone number (Hope this part makes sence)
i feel that these notes are important here because this point might prevent you from accessing your pictures and since you cannot see your screen, it is important that you know what to do at step 2.
step 3. Press the digit 3 ( or - scroll down 2 times and press ok) this will take you to the third option called Online Albums.
step 4 press the down button once( this will select the option called Upload picture) and press ok.
if everything went right, you should now be in a screen called In Camera with your left soft key now called Upload and your right key called Options
Step 5 click the left soft key (Upload) do not worry about selecting the pictures since the next step will take care of that.
step 6. press the down button once. this will take you to Upload All option. press OK
step 7 the phone will ask you where to take those pics. just click OK again to take them to the default album called My Uploads
step 8 DO NOT FLIP CLOSE YOUT PHONE!!
STEP 9... there is no step 9! the phone is now uploading the pictures to your online album called My uploads just give it a couple of minutes..
Tips.
1 It would be best to do this in an area you are sure has decent network service.
2 just to be sure, please have your phone on the charger( you are dealing with pictures as well as data transfer) when i was testing out these steps, i lost a bar of my battery so just be safe..
