Sony KDF-E50A12U 50" LCD HDTV Logo
Posted on Feb 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our tv is switching itself off then flashing 2 red lights, which i read on the internet is a problem on the power supply circuit. Can replacement power supply boards be bought, if so where from & do you think this may cure our problem. Thanks
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 03, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
621
Points
I have a kdf-e50a12u sony Bravia and it switches itself of after about half an hour. any one have any ideas why.
  • ray7540 Jul 09, 2011
    I have the same problwm, goes off and ghen 2 red blinks. Did anyone accomplish to fix the problem and how ? I dont know what to do. The door switch works fine.
  • Anonymous May 17, 2012
    I had this on a KDFE50A12U I bought yesterday, it was a plug off in the centre behind the shiny steel stiffener, powers up great now, that wire was the feed to the lamp or fan without that connected it won't switch on.
Anonymous
Level 3:
  • Sony Master 5,138 Answers
  • Posted on Feb 12, 2010
Anonymous
Sony Master
Level 3:
Answers
5138
Questions
5
Helped
1003617
Points
13534
Have you replaced Lamp? Mats Electronics has them 1-800-628-1118
1helpful
2answers
Hisense TV Red Flashing Power Light Has Sound But No Picture
1. Why hisense TV red flashing power light has sound but no picture
There could be a few reasons why your Hisense TV has a red flashing power light but no picture. It could be an issue with the TV itself, the power supply, or the input signal. Let's take a look at each of these possibilities in turn.
2. How to fix hisense TV red flashing power light has sound but no picture
If your Hisense TV has a red flashing power light but no picture, there are a few things you can try to fix the problem. First, check to make sure that the power supply is plugged in and that the TV is receiving power.
Next, check the input signal to make sure that it is compatible with the TV. Finally, if the TV itself appears to be the problem, you can try resetting it.
3. What to do if hisense TV red flashing power light has sound but no picture
Turned tv on 2night had picture and sound for approx 3 minutes then tv turned itself off had 2 flashing red lights turned tv back on no picture or sound then turned itself off again
B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
2answers
TV won't come on
Sounds like it started "Protection Mode" because of a failed electronic part inside the TV. When this happens, the TV will keep turning itself OFF or will not turn ON at all. This keeps the other part inside from being damaged. The flashing red light should no doubt be an error trouble code. But, I don't have the actual Service Manual for your TV model to tell you what the code means. Most protection mode problems are a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The common part to go bad for flat panel screens circuit board that powers the screen. Most manufactures call it a Backlight Inverter Board.
But, I can't say what is 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. You can again try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light flasing codes, circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15 by searching on the internet with the part number.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
1helpful
42 LG plasma no picture but sound. found internal fuse had gone so replaced. Then when switched on it stays on for about 5 seconds and switches itself off again. Replaced power supply and now when switched...
Sounds like it started "Protection Mode" because of a failed electronic part inside the TV. When this happens, the TV will keep turning itself OFF or will not turn ON at all. This keeps the other parts inside from being damaged. Most likely the TV has a power supply related problem. The common part to go bad for flat panel screens circuit board that powers the screen itself. Most manufactures call it a Backlight Inverter Board.
1. Best thing to do, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. Its the best repair guide material for fixing TVs. And most cases the new part cost less than $15 by searching on the internet with the part number.
2. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
7helpful
I have a 50inch lg ready tv but wont switch on red power light there but when i switch on light goes away for 15 mins but tv wont come on
Sounds like it started "Protection Mode" because of a failed electronic part inside the TV. When this happens, the TV will keep turning itself OFF or will not turn ON at all. This keeps the other part inside from being damaged. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The common part to go bad for flat panel screens circuit board that powers the screen. Most manufactures call it a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15 by searching on the internet with the part number.
2helpful
Flashing red light on front of Sony Wega flat screen tv
Normally, this happens when the TV detects a bad circuit board and goes into " Protection Mode ". The blinking red light should be a error trouble code. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
2answers
Red light on my tv is blinking. no pic nor sound. what's wrong with it?
if it is blinking rapidly, you can try to unplug it for an hour or so and see if it comes back on. if it does come back on, your unit may be overheating. otherwise, there is a chance that the power supply is going out on the unit and you will need to contact a local repair shop.
We switch the TV on and it goes on for about 10 seconds and then shuts itself off. Any ideas?
Normally when this happens, the TV goes into " Protection Mode " because of a failing circuit board. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The most common thing to go out on flat panel TVs is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
1. If by chance the TV is still under warranty, go that route.
2. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light flashing codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
3. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
1helpful
I have a red light flashing insted of a green light
Right now the TV is in " Protection Mode " and the blinking red light is a trouble code.
Try leaving the TV unpluggeds for 30 minutes, that way the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
6helpful
2answers
My sony bravia tv is flashing red stand by light
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
