I want to change the language of samsung gt-c3212 from arabic to english
SOURCE: How do i change my language from arabic to english
This will work for all 2630's from whatever language it is currently set at to your desired language. Press the center square button to get the menu. Scroll down until you see the small wrench - menu #4. Press the square (Select) button again. Scroll down to #9 - the icon will look like a small phone with a wrench - press select. Press select again - menu #1. Press select again - menu #1. You should be able to see English as an option. Scroll down and select again and you should be good to go. The Nokia menu sequence is: Menu, 4, 9, 1, 1. Unfortunately, this phone does not do jumps - so you must scroll down manually.
SOURCE: i have brought gt-e1107 samsung mobile i want to
To change the setting from Arabic to English Samsung E-1107(By Criz Lalap)
0. Press * key for 2 seconds to unlock/ unlock the keypad
1. Press the upper left key( Go to Menu)
2. Navigate to lower right icon then press Ok( Go to Setting)
3. From the top navigate 3 steps downward then press ok(Phone)
4. Select the top list(Language) then press ok
5. Scroll left to right to find English language then press ok.
SOURCE: I have a Samsung Galaxy
I have a samsung GT - I9000 but it is in arabic how can I change the language in French.Very Urgent.Thanks.
