Question about Maytag Neptune MAH6500A Front Load Washer
It takes 3 times as long for the clothes to dry
  • 572 Answers
Check the vent.
Posted on Feb 12, 2010
Anonymous
SOURCE:
Taking to long to dry clothes
How long does it take you to dry your clothes? Normally, it takes 50 minutes (1 cycle) to 1.5 hours to completely dry clothes. However, if it's taking you at least 3 cycles (probably 2.5 to 3 hours) to dry a single batch of clothes, then, there might be a problem with your dryer's igniter.
Jan 09, 2014 | Speed Queen AGS17AWF Gas Dryer
I have a GE washer/dryer Model WSM2700RAWWH stack type and the dryer is taking very long time to dry the clothes. Please advise if it can be fixed. If not what will be best alternate washer/dryer stack...
first things first. if any dryer regardless of brand takes 2-3 hours to dry cloths 90% of the time it is your exhaust duct. take the exhaust duct off the back of the dryer and dry some clothes if the clothes dry fast then you need to have your exhaust duct cleaned. either DIY or call a professional
if it still takes a long time to dry then it could be the thermostats or the thermistor.
but in my experience its normally the exhaust duct.
Feb 10, 2011 | GE Washing Machines
Dryer is hot when opened, but takes 3 or 4 timed cycles to get clothes dry on very dry setting and timed setting
Check for a restriction in exhaust system,not just behind unit but all the way to outside vent,should feel warm decent airflow at outside vent.If not all you will end up with is warm moist clothes,You need good airflow to take away the moisture in the clothes not just heat.This issue can happen slowly over time and next thing you know its taking two or three times longer to dry even though when you open the door its hot inside.
Good luck
Aug 08, 2010 | Amana Dryers
Dry take hours to dry
need to check hi limit thermostat on element make sure it is not cycling to soon
Apr 13, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer heats up but doesn't dry clothes take 3 hours after restarting 3 times to dry 3 articles of clothing.
It's not your heating element. Your venting system is clogged. Like mine was. You'll need to take care of this ASAP and from then on at least once a year. It is a fire hazard. Not only that if left this way It can kill your heating element.
Oct 15, 2009 | Whirlpool LER4634J Electric Dryer
My dryer takes 2 to 3 cycles to dry my clothes.
Check the following areas to combat this issue. in most cases, this will be a Venting issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
Washer won't spin dry clothes
What model is in reference here? Please post back with model number.
Jul 02, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Dryer heats up but does not dry clothes
first take the venting off the back of the dryer and dry a load if dryes normal replace venting if takes a long time to dry have a repair man clean the dryer
Jun 12, 2008 | Kenmore 74602 Gas Dryer
Maytag Neptune MAH6500A Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
