Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
Posted on Feb 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water leaking from bottom of disposal where
There is an opening at bottom of disposal where electrical line exits. Water is leaking from that hole. Is there a seal that has gone bad causing this leak? Can that seal be replaced?
Anonymous
Level 3:
  • Ace Hardware Master 43,501 Answers
  • Posted on Sep 29, 2010
Anonymous
Ace Hardware Master
Level 3:
Answers
43501
Questions
0
Helped
10842896
Points
101584
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
t
Internal leak
Wrap a dry towel completely around the outside of the disposal above where you believe its leaking but below any drain. Secure in place with tape and wait. If towel stays dry, then ok its leaking through the bottom bearing and replace unit.
If the towel is wet... keep looking.
tip
If you have a garbage disposal and you find that it is leaking then you need to first of all figure out where exactly the water is coming from. The reason is that depending on where it is leaking from will determine whether it is easily fixable or if it would be better to just replace the entire garbage disposal.
With this is mind the best way to find the leak is to put the plug in place and fill the sink with water. Then place a food coloring or non-toxic dye into the water. Red often is a very easy color to spot under your sink. Then let the water down the sink with the disposal running. If the water runs down the side of the garbage disposal then you have a leak at the seal where the garbage disposal hooks up to the sink. This can easily be fixed by removing the garbage disposal, cleaning the old plumbers putty off of the ring and sink bottom, and then reinstalling the garbage disposal.
If you do not see any water coming down the sides, but it comes out the drain pipe, then the drain may be clogged and/or the seals for the drain piping are bad. The seals can easily be tightened. They may have come loose from the vibration of the motor or just the expansion and contraction that occurs from hot and cold water going down the drain lines. If the drain lines are clogged a garbage disposal safe drain cleaner can be used or the drain can be taken apart, cleaned and snaked.
If you have the dreaded water coming out of the bottom of the garbage disposal then you have the worst problem. The internal seals that are to prevent the water coming into the motor where the shaft goes through to the actual grinding chamber have deteriorated to the point where they no longer keep the water from coming into the motor. The water will make its way down through the motor and run out the weep hole or the reset button.
These seals are replaceable, but a new motor is needed for a complete fix on many garbage disposals. Because of this, many times the parts to repair this leak will be at least 75% the cost of a new garbage disposal. This makes repairing your garbage disposal, not a very good option. Replacing the whole unit is often the best way to go to make sure you have a fix that will last for a longer period of time.
That should cover all of the potential ways that your garbage disposal can leak. Hopefully you are able to pinpoint the leak and make the correct call to fix your leaking garbage disposal.
1helpful
2helpful
My badger 5xp is leaking drain water from the red reset button?
You have to replace the disposal.
Disposals are sealed units, and cannot be repaired once they rust out.
If water is coming out red reset button, then that is very common point for water to exit the steel canister.
The motor is getting wet.
The electrical wires are getting wet.
This is a shock hazard, and sink and disposal should NOT be touched when switch is ON.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Just got brand new sink, there are two holes at the bottom side of it and when i run the water, water comes out the hole on the right?
there should be two openings at the bottom, one for the drain to the drain line, and one towards the top for a dishwasher to drain into the garbage disposal. If you do not have a dishwasher, the top drain should come with a cap, and the lower drain is what the drain pipe gets tied to.
1helpful
Water leaking from bottom of disposal. coming out of an open hole on bottom.
After seeking the answers in solving my problem I decided to just replace the old disposal with a new one. Considering the costs it was easier to replaced than to repair. It the end it would result that I still had a disposal that was old and could develop problems down the road. Thank you
2helpful
2answers
I have water leaking from the bottom of my waterheater PE50T9A
It is possible that the water heater has a leak at the bottom. They eventually rust out. The valve should be removed if it is leaking and you should replace it. They are cheap. Be sure to use teflon tape to seal it back up
7helpful
Water leaks from two locations on my Badger 5, 1/2 hp disposal
These holes are probably due to wear, as they are at about the level of the cutter. In general, residential disposals are not repairable and once they begin to leak, they must be replaced. The Badger series is Insinkerator's budget line and probably has about a 5 year lifespan with normal use.
18helpful
3answers
Garbage disposal leaking water from bottom
If it's leaking directly from the bottom, then it's the flywheel seal. For about $20 you can fix this by unplugging and disconnecting the garbage disposal from the sink, taking it apart and replacing the flywheel seal. I've had to do this only once in my entire life, so it is rare, but happens.
If the leaks comes from somewhere else and just happens to drip along the side and looks like it's coming from the bottom, then you've got problems with the installation. You may be able to fix these types of leaks by tightening the mounting bracket and/or hoses.
Oct 05, 2008 • Home
Top Ace Hardware Electrical Supplies Experts
Mike Cairns
Mike Cairns
john h
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
