Is there a Need fuse location?
SOURCE: Roper dryer again
if its a thermal fuse located on rear bulkhead of dryer, youll find it by removing back cover of dryer, little white thermo,if bad there will be no continuity through it
SOURCE: dryer not heating
Everthing is on the back. Unplug the appliance. remove the rear panel. This is a sweet machine. Very easy to fix. The element comes right off easily (2 screws either side of it). Look for breaks. if the element is kosher check the hi-limit mounted on the same heater above on the left. Hey here is some pic:NOTE Not shown is the 300 degree limit mounted at the top!!!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: i have a roper dryer
remove the rear panel the thermal fuse is mounted the the exhaust duct left of the vent hole held in be one 1/4 nut
SOURCE: dryer won'y heat up
you either have a bad heating element or your limit switches are out..it could be either or both they are what control the heat
