Flashing/Flickering bright lights. Any background window will flicker, Sky in picture will flicker, street lights flicker, etc. I couldn't watch a cartoon for the flickering of the brights. Any white or bright color flashes brighter and then back to norm. If it helps any, I see a few red pixel flashes on black backgrounds.
SOURCE: Flickering/pixelating screen on LTV-27w6 HD after 30 minutes.
Sound like dry goint on Power Supply bord. I had the same problem and resolder most of the parts of the power supply and TV was ok.
SOURCE: Stuck Pixel
THE DLP CHIP. Is the set still under warranty? And if it is they are going to tell you it is within specifications. Especially if it is in the B ZONE. which means not in the middle basically. If it is under warranty and it is in the middle of the screen then they will most likely exchange the "Light Engine". Good luck and let me know how that works out for you...Thank you Guru Jay
SOURCE: Flashing picture
Sounds like main board fault. Contact any "Experienced" service technician, or, the authorized service center for Viore.
Gopakumar Gopalan Google
