Is this a loud whistling, like a dying bird stuck in your freezer, or is this a lower pitched, sort of gentle whistling sound. If its the former, you likely have a faulty freezer fan motor. replace
if its the latter, sounds like you may have a issue with the door damper, which allows the air flow from the freezer into the refrigerator. However, assuming you dont have any cooling problems, you didnt mention if you do, it may simply be a normal occurance, as some makes and models open and close this damper door automatically, and when it is closed, can sometimes cause a low whistling noise
