The teeth on the blender rubber clutch for my Kitchen Aid blender were stripped. How do I replace the rubber clutch?
Hiya,
Sorry you are experiencing problem with your appliance. We have created help pages and videos to help you resolve this issue, please see the relevant links below for you perusal:
https://www.kaparts.co.uk/Help/KitchenAidHelp/KitchenAidBlenderHelp/KitchenAidSplitCouplerRemoval/tabid/180/Default.aspx
https://www.youtube.com/watch?v=Qy9gCwSgUVg
https://www.youtube.com/watch?v=nhnuaSCoVjQ
Hopefully you will find our information helpful. Should you require any help, please don't hesitate to contact us.
SOURCE: Kitchen Aid Blender Rubber Coupling replacement
Someone else suggested a link that explains exactly how to unthread the old coupling... and it works. It took me about 90 seconds to fix my blender. But in case that link is dead, here's a summary:
(1) Note that the coupling (the round part with teeth) is threaded to the blender motor in reverse to a standard threading. So it screws off just like a bottle top, but in a clockwise direction.
(2) place the blender base on a tabletop, facing you. You should probably unplug it.
(3) take a punch or a flathead screwdriver, and place it against one of the coupling teeth that is furtherest away from you.
(4) strike the back of the screwdriver with a small hammer or maillot. The result will spin coupling clockwise. It may take several tries, but the coupling will eventually spin clockwise faster than the motor, and it will begin to unthread.
(5) unscrew the old coupling, and screw the new coupling into place (counterclockwise). Note that the new coupling will tighten itself every time you use your blender, so no need to worry about tightening it too much.
(6) Make a smoothie to celebrate your success!
SOURCE: the rubber gear that turns the blade in the
The piece that you need is referred to as the coupler. The coupler is a breakway part that is designed to shear and/or wear down in the event that the blender is overloaded. This is to avoid damage to the motor.
The coupler may be purchased individually and is an easy repair that can be done at home. You may purchase the part and access step-by-step replacement instructions at the following link:
http://www.mendingshed.com/kacoupling.html
i HAVE THE SAME PROBLEM AND I WOULD LIKE TO KNOW AS WELL THANKS
