If your Kenmore washer series 400 model 22102 is dripping water in the tub after the cycle is complete, there could be a few potential causes. Here are some things to check:
Water valve: The dripping could be due to a faulty water inlet valve. This valve controls the flow of water into the machine and if it's not closing properly, water can continue to drip into the tub even when the cycle is complete. You may need to replace the water inlet valve to fix the issue.
Water level sensor: Another potential cause of dripping could be a malfunctioning water level sensor. This sensor tells the washer when the tub is full and it's time to stop filling with water. If the sensor is faulty, it may not be accurately detecting the water level, which could lead to dripping. You may need to replace the water level sensor to fix the issue.
Drain hose: If the washer is not properly draining, it could also lead to dripping after the cycle is complete. Check the drain hose for any kinks or clogs that could be preventing water from draining properly. You may need to clean out the drain hose or replace it if it's damaged.
Overloading: If you're overloading the washer with too much laundry, it could be causing water to overflow and drip into the tub after the cycle is complete. Make sure you're following the manufacturer's guidelines for load size to avoid overloading the machine.
If you're unsure of how to diagnose or fix the issue, it may be best to consult a professional technician or reach out to the manufacturer for assistance.
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water
when is filling only, check the following:
1.Fill
hoses
2.The water mixing valve 3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the
following: 1.The pump 2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the
following: 1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses 5.The stem & seal
I have had similar situation with my top load washer over the years. It has been the timer 3 times and the water pump 1 time.
How I came up with it being the timer. The knob which you set it on the type wash you want. Put it on a different cycle and see if it completes the wash cycle. example if my washer is not working when I put it on heavy wash cycle I might put it on the casual wash cycle. If you change the wash cycle and it goes through the complete cycle it is probably the timer which is part of the knob you change for different wash cycles with.
If it stops when it is time to empty the tub on all cycles it may be the water pump which empties the tub. The one time I had a problem with the water pump it was a small piece of coal had the pump locked up. I never figured how it got out of the tub and to the pump but I put it back together and it worked fine.
It should not go into the spin cycle if the tub is full of water.
Two of the timers I bought cost 40 - 60 dollars. One was 140 dollars I bought a new washer that time because the washer only cost 220 dollars.
Your water inlet valve where the water supply hooks up to the washer is not sealing good.It can get sediment in it and cause this. Having a well for water supply can cause this more than water that has time to settle.
It sounds as if you have something acting as a flap causing the restriction. You should take the hose that leads from the tub to the pump off and see if there is anything just inside the tub. I have noticed that alot times you could have a coin that blocks the opening. You may have to remove the inner tub to remove anything in there
Sounds like what you are describing is the timer on the dial is not activating the next cycle. Timers are usually the problem when the cycles do not complete there cycle
try turning the mach off while it is spinning and filling.if it continues to fill or drip heavy,the mixing valve is not closing completely and needs to be replaced.if the water stops when the mach is turned off,there is a problem with the pressure switch.
at end of wash cycle water still remains in bottom of washer
