There is no reset just because you added memory.
If you have 2- 1GB sticks, try both , one at a time.
Your system spec's and manual tell nothing which dimm banks are suppose to be used , and if you can install 2-1GB sticks,
all it says is it can handle 2GB.
Now it says 512MB, sticks, this could mean you can only use 4-512MB sticks to get too 2GB,.
Now it does not tell which dimms are used if you have 2-1GB sticks,
You have 4 slots, the first two and the second two, most times, you either use the second bank of each pair, or the first slot of each pair,
but as I said, your system does not say.
So you can try both ways and see if one of them work.
Sorry I can't be of more help,but you system has a poor manual
on memory placement.
The maximum memory that this desktop can accept is 2GB. Please make sure that the 1GB ram modules are PC3200, 400Mhz, DDR400, 2.5v. These are the only 1GB modules this computer can accept.
