Thanks for contacting FixYa Support.
I have repaired numerous iMac G5 17" models for a while now and because I have, I can tell you just from the symptoms you have described, this is potentially a power supply issue.
However, the iMac G5 17" have been known to have swollen capacitors, which can also ultimately impact the power management / performance of your iMac.
If you are able to, very carefully and don't touch them, you can look on the iMac's main logic board to see if you notice any swollen capacitors. If you are not sure what a capacitor looks like, they look like mini batteries connected to the board.
Should you do this and find that the capacitors are ok, then I would recommend for sure, that you look into replacing the power supply.
For your model of iMac 17" provided it is not an Intel-based iMac, the part number you will need to source is part# 661-3627. Below, I have also provided the most inexpensive price for this iMac power supply per this link:
AppleComponents.comYou may find even lower prices for this iMac 17" power supply, if you search online further, but this is one of the better online Apple components vendors. Therefore you should be able to see and compare the prices on this website, with some of the other vendors
advertising the same Apple power supply for the iMac 17".
I hope this helps. If you have any more questions on this subject, simply reply back to this post.
Best Regards,
-Mactechtrainer
