No the new Quinny Zapp Xtra sun canopy is part of the seat fabric.
If you wish to turn your standard Quinny Zapp into a Quinny Zapp Xtra you need to purchase the Quinny Zapp Xtra seat unit as an accessory from your local retailer as it will have the seat frame and the adaptors required to fit it into the chassis you have.
Visit www.quinny.com to find your nearest retailer.
Yes the new seat unit can be used with old zap.You remove the fabric seat (look on u-tube if you don't know how)the new seat unit then fits on to frame via the addapters that come with the xtra seat unit, at the point where the car seat addapters fit.There is a large push button on the top of the seat unit which you push in to recline or sit up the seat, and a little one too next to it, that needs to be pushed away from the larger one, while you hold the large button down when you want to remove the seat unit.I found fitting the xtra seat very easy.To fold the zapp you Must remove the entire seat unit as it won't fold with it on, unlike the old one.
sorry but no it dosent lay back,you need the new zapp xtra seat unit,this faces forward or bk wards,can be bought on ebay for £99.00,and i must say these are brill.as i just bought one,they fit straight on to your zapp frame every thing is included in the box,caroline
The original Quinny Buzz 2005/2006 chassis is not suitable for fitting the current seat fabric. However you can purchase a sub seat (seat frame) which will fit onto your chassis (RRP 75GBP) and the current seat fabric will fit onto that (RRP 40GBP). The Quinny Dreami carrycot is suitable for use on any Quinny Buzz chassis. You can order the sub seat and seat fabric via your local Quinny retailer or direct from the customer service department on 01284 413 141 Mon-Fri 8.30-4.30.
try contacting Dorel - the parent company for Quinny at www.dorel.co.uk You will find phone numbers for customer services and they can send you what you need.
Hi new frame should be ok, the only frame that is different is the older 2005 frame, if you remove your seat unit and check the posts on your seat unit (the bits that slot onto the buzz chassis) if they are both the same and have rounded ends then this is the older model and wont fit the newer frames, but if one of the posts is rounded and the other is shaped like a turret then all the frames 2006 onwards will be ok. :)
