Question about NAD T761 Receiver
How can I reset my NAD T747 to factory defaults?
  • 69 Answers
Restoring your T 747 to its factory defaults: At FM mode, press and hold front panel’s LISTENING MODE button until the VFD shows “Factory Reset”.
Cheers!
Posted on Feb 15, 2010
  • Francois van Rooyen Dec 29, 2011
    Then switch the unit OFF at the mains and switch on power up after about 10 seconds
6ya staff
SOURCE:
Won't stay powered on. Clicks off within few seconds. Amber power light stays on.
Could be speaker wires shorted together, but it is more likely that there is a fault in the output transistors or the power supply. The front right and left normally produce the most sound output and those transistors run hotter than the other channels. If you have the equipment and know how to check the output transistors, I would start there.
May 05, 2015 | NAD T747
My NAD T747 keeps shutting down in Protection Mode at 6db when it used to go much louder. I cleaned the unit. Still nothing.
Modern AV receivers such as your NAD have protection circuits to prevent damage when there is a short on the speaker terminals. Look carefully at the speaker connections on the back of the AV receiver- for example, the speaker cable for front left speakers labelled + and - : there should not be any stray strands of wire that connect from + to - ; this would be a short circuit. Check each of the connections on the AV receiver as well as on the back of each of your Speakers themselves. Also ensure all connections are snug (do not use pliers). If this does not solve your problem, you may need to take your AV receiver on for a service checkup. Good luck !
Dec 12, 2014 | NAD Audio Players & Recorders
How to connect ONYZ home kit sirius to a NAD T775?
Try a factory reset of the receiver.
To perform a factory reset, press and hold the MENU and SOURCE buttons until Factory Reset is displayed. Then Power Off from Back panel for 1 minute and power up normally.
You may have damaged the receiver if you did not power off before installing the Onyx module.
Jul 27, 2014 | NAD Audio Players & Recorders
Factory reset
I have the same question.
Dec 07, 2013 | NAD Audio Players & Recorders
How to reset a NAD L54 DVD reciever?
This is the technical solution, you have to open the unit:
Locate IC33 and connect pin 6 to ground, connect power, and then remove the ground connection at pin 6.
The unit will then boot up in factory default.
Henrik Pedersen
Jul 20, 2012 | NAD Audio Players & Recorders
Why no sound what do i need to do
You could help by providing more info, such as manufacturer, equipment type, etc. What do you have plugged in? What is its power source, etc. Fuse?
Jul 16, 2011 | NAD T747
Forgot pass word nad can't get on computer can reset pass word because i don;t have reset disk
try hitting f10 on the start up, this will take you to system restore, yes you will lose all your valuables on you computer, but this will restore your computer to factory defaults. hope this helps..
Mar 10, 2010 | Acer Aspire 5100 Notebook
NAD T747 Shutting Down
get a fan or do a re-stack...open the back of the e-center, Yes it will do a thermal shutdown... just like 3 mile island
Dec 10, 2009 | Audio Players & Recorders
Don't know my network name or password to hook up wireless printer
You only choice may be to factory default your linksys.....once you factory default the node, you should be able to login with the default username nad password
Oct 28, 2009 | Linksys Wireless-G WUSB54G 802.11g/b
NAD T761 Receiver Logo
4,309 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
cheekygr1n
Level 1 Expert
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
