Please take note that the following steps is in assumption that you are using a Windows operating system.) As I have found out in the iTunes support in apple.com, this symptom may be caused by anti-spyware software preventing iTunes from installing correctly. One such application is
SpyCatcher. Before installing iTunes, temporarily remove this software to allow the iTunes installer to complete.
If you are still having trouble installing iTunes for Windows,
follow the troubleshooting suggestions described in this article.
General installation troubleshooting
Important:
iTunes installation is successful a majority of the time after
completing these troubleshooting procedures. If one step does not
resolve your issue proceed to the next.
1. Empty your Temp directory and restart
Windows XP:
- Choose Start > My Computer (or double-click My Computer on the Desktop).
- In My Computer or Computer, open the "C:" drive.
- Open Documents and Settings.
- Double-click the folder titled with your username.
- If you see a Local Settings folder, skip to step 10. If you don't see a Local Settings folder, proceed to the next step.
- Choose Tools > Folder Options.
- Click the View tab.
- Select the option to "Show hidden files and folders."
- Click OK.
- Double-click Local Settings.
- Right-click on the Temp folder and choose Delete.
- In the confirmation dialog that appears click Yes.
- If
you are unable to delete the Temp folder, close all programs,
especially those in the Notification area ("System Tray") of the Windows
Task bar and repeat step 11.
- Restart your computer.
Windows Vista and Windows 7:
- Choose Start > Computer
- In Computer, open the "C:" drive.
- Open the Users folder.
- If you see an AppData folder, skip to step 10. If you don't see an AppData folder, proceed to the next step.
- Choose Organize > Folder and Search Options.
- Select
the option to "Show hidden files and folders." (In Windows 7 this
option will be called "Show hidden files, folders, and drives").
- Click OK.
- Double-click the AppData folder to open it. If Windows needs your permission to continue click Continue.
- Double-click the Local folder to open it.
- If
Task bar and repeat step 12.
2. Completely remove iTunes and QuickTime
For Windows XP, follow instructions in
Remove and Reinstall iTunes, QuickTime, and other software components for Windows XP.
For Windows Vista or Windows 7, follow instructions in
Remove and Reinstall iTunes, QuickTime, and other software components for Windows Vista.
Note:
Songs you purchased from the iTunes Store or imported from CDs are
saved in your My Music folder by default and are not deleted by removing
iTunes.
3. Install the latest version of iTunes
Once
you have completed the above steps to Empty your Temp directory,
Completely remove iTunes and QuickTime, and Clean up iTunes installer
files on the computer, you can install the latest version of iTunes from
http://www.apple.com/itunes/download.
Additional troubleshooting
Make sure you have administrator-account access
To
install iTunes or QuickTime software, you need to be logged in as an
administrator on the computer. If you're not sure if you have
administrator-account access, contact the owner of the computer or your
system administrator.
Get the latest Windows updates
The
first thing to do when troubleshooting an installation issue on a
Windows computer is make sure you have the latest Microsoft Windows
updates installed—to get the latest updates, go to the
Microsoft Windows Update page.
iTunes
and QuickTime software for Windows require Microsoft Windows XP or
Microsoft Windows Vista with latest Service Pack installed.
Disable other conflicting software
In
Windows, some background processes can cause issues for other programs
and processes. These conflicts can prevent applications such as iTunes
and QuickTime Player from installing. See
Using MSCONFIG to troubleshoot conflicts in Windows XP or
Using MSCONFIG to troubleshoot conflicts in Windows Vista and Windows 7 for assistance disabling conflicting processes.
Additionally,
some third-party security software cannot be disabled using Selective
Startup (MSConfig). Because of this, it may be necessary to temporarily
manually disable such software while troubleshooting installation. For
assistance in configuring or disabling your security software, please
contact the manufacturer.
Make sure your folder names don't contain strange characters
If
the iTunes installer (iTunesSetup) is not responding or appears frozen
after launching the installer then the folder where the installer is
stored may contain unusual characters. If you notice that the iTunes
installer or stored in a folder like this, either rename the folder or
move the iTunes installer to another location such as the Desktop before
launching.
More help
If these steps don't help, you may be able to find a solution to your issue by searching the
Microsoft support website.
If the above troubleshooting steps have not helped, proceed to the following steps
Solutions to common installation errors
Here
are some common symptoms you may see when installing iTunes and
QuickTime for Microsoft Windows. If you are experiencing one of these
symptoms, try the suggested troubleshooting steps:
If you only need to install QuickTime, or if iTunes installs but QuickTime installation did not complete
Try downloading and installing the standalone version of QuickTime from
http://www.apple.com/quicktime/download/. Be sure you download the version that does not include iTunes.
