Hi friends,
My pc 102 Intel Original board,
512 RAM
160 GB HDD
i have a problem that my CCTV systems not working with this Intel board,
my CCTV Hardware is PCI card,
plz help me friends
Raj
Either contact with any hd security cameras expert- http://wettersolutions.com/why-choose-us/ or following points:
Check the Security Camera Connection and Power.
Make Sure the Cabling Is OK
Check the Settings If Security Camera Won't Work
Reboot the Security Camera to Fix Issues
Check If There Are IP Address Conflicts
Update to the Latest Firmware to Solve Security Camera Not Working
Update to the Latest Client Software
Here is solution for u
frist of all see the link know your how much is powerful
http://www.intel.com/products/motherboard/d102ggc2/index.htm
then after format your pc reinstall windows carefully then after plug in your cctv card install the software of your cctv camera
then after your problem will be sloved
just tray it man enjoy
Find out your devicemanager 4 chhanel card driver install properly
or not after that verify your do you install directx
What kind of error display
which card use 4 channel , 8 ,16
no any alternet way to find out error so format system and
reinstall windows oprating system and cctv application software
i have install cctv project more than 30 to 35 but i phase the problem is cctv software and driver missmatch that's i realize
so reinstall application and must care about card driver selection
b'coz of so many driver company gives you on your driver cd
i am using diginet 4 channel card,
but when i install software till then every thing fine, but when i start the application at that time the application not work.
I have install driver proper by inf installation. i have installed direct X 9.0c November 2007 from my chip dvd but problem that when i start the application at that time application not work proper it gives the massage that this application need to close so and so ........
when i lick on ok then the application close.
