My remote control is a model CT-90233. Several of the buttons do not work (the 6, 9, and the power buttons). To get the set to turn on, I have to hold the power button down for a long time (several seconds) finally, the light indicator on the remote will light up beside "TV" and the set will turn on. I have replaced the batteries and gotten the exact same result. I don't know that any liquid have been spilled on it. Any suggestions??
Your remote is old and needs to be cleaned and rebuttoned(you can do this yourself) open up the battery panel and look for small screws to take of the case. you need to dust it out with compressed air. and reline the buttons. when you push down on the power button it probbaly is not making complete contact with the button, take a small thing and poke the power button without the buttons on. see if that works. if it turns on right away with direct pressure to the power switch then you just need to make sure your buttons are making complete contact. if that dont work then your circuit is screwed. you need a new remote or a new tv.
