Refrigerators Logo
Posted on Feb 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have some problem with my AMANA BX20ML Model REFIGERATOR
Some one can help me? I have some problem with my refrigerator. It's an old model of Amana. Model no is BX20ML. Its freezer is not cooling enough. It is an energy saver model. The freezer has a dial out side to keep the required cooling. There is another switch to keep the freezer in energy saver position. My little baby girl moved the switch. I do not know which position the switch should be so that it should cool enough to freeze the stuff inside. Now the motor is running and cold air is coming out through the vent inside, But it is not freezing the food. Please tell me which position I should keep that enegry saver switch. Left side up arrow says ' reduces exterior cabinet moister' and Right side down arrow says ' energy saver' . Both sides have 3 positions from top to bottom. And there is only one switch for these setup. Please tell me which position I should keep this switch to get enough freezing temp.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
356
Points
This refrigerator is over 20 years old. Time for a new one.
geapptech
Level 2:
Habit-Forming:
  • Expert 157 Answers
  • Posted on Feb 17, 2010
geapptech
Expert
Level 2:
Habit-Forming:
Answers
157
Questions
0
Helped
56311
Points
343
You may have a bad condensor fan motor or paper may have gotten pulled under the fridge and jammed the fan blade. The energy switch will not help with cooling it only controls exterior moisture.
How to install amana refigerator defrost heater model number isabb223deb
I cannot find a model number ABB223DEB are you sure that is the correct model number? Thanks John Tripp Appliance 911
Refigerator door rubs
hi.a bit vague but i would check the door hinge bushes first.i'm assuming door seal ok.hope this helps.Ali
Amana bottommount refigerator--ABB1922FEW--- BUY 08-03-07 AMANA REFIGERATOR WARM---60+ DEGREES FREEZER ---YES---10 DEGREES FREDD- APHASIA--COMMUNICATION PROBLEMS--- NICKNAME: giesslerf PASSWORD: abd7f
Wow
Ican not understand what you need.
So I am guessing here
Ice has built up on the evaporator coil stopping air flow to the food section.
Try manually defrosting the fridge. If this works then the auto defrost cycle has failed and you will need to get a technician to help you
Refigerator has no cold air freezer works good
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Unit was making noise. bottom freezing, top meling, no cold air blowing into the refigerator from freezer
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Refigerator is freezing the food at all settings
heatman101
The Amana refigerator I have stopped cooling. There is power to the unit, the lights work but the unit is not cooling. The unit clicks every few minutes.
Start capacitor,start relay, overload and windings in compressor need checked. When clicking like that the compressor is overheating and could damage the internal overload. Send model number so I may tell you the correct parts. I will be here if you need, Sea Breeze
NEED BACKPRESSURE ON AMANA REFIGERATOR
Domestic Amana
It would be 28k below the fridge temp. If the fridge was so at 4 degs
you would have minus 24 suction at 29kpa r12 or 14kpa on r134a
Most of the amanas work in a vacum so make sure you put your gauges on and off when the unit is off so you dont let air in.
Refigerator / freezer not cooling properly
You have a bad defrost heater.
READ THIS PWEASE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
