Acer Aspire 6920 Notebook PC Logo
Posted on Feb 16, 2010
CineDashMediaConsole.volume not working.
Hi to all.well i have problem with my aspire 6920g .The CineDashMediaConsole works but not the volume i have tried all the suggestion .batterie out.Old power butten in fo 30 sec.and still does not work.any sugestion. thx
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Apr 04, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6181
Points
Cinedash FIX for Windows 7
This works to fix the CineDash Media Console!
I had the same problem with my Aspire 8920G
Now it works fine.
Getting the CineDash Media Console and Launch Buttons working
If you have problems with either the CineDash Media Console or Launch buttons then you will be happy to hear that the solution for fixing these is easy!
The first thing that you will need to do is install the “Launch Manager” which can be downloaded off the Acer website. Go to http://www.acer.com and click the service support, then driver download. Go to your model. Download the Launch Manager on the acer site. The filename should be “Kilimanjaro_v2.0.00_Vistax32×64_XPx32×64.zip” the version of Launch Manager under the Windows Vista operating system .This will get the Email, Web and Empowering Technology buttons working with their default settings. If you need to change what the buttons do, you can launch the application named “Launch Manager” in the start menu.
Uninstall any previous version of Launch Manager
The solution to my problem was to get the Launch Manager to run in compatibility mode for Windows Vista Service Pack 2.
Unzip. Explore the new folder and right-click Setup.exe.
To do this go to the Launch Manager Install directory (C:\Program Files\Launch Manager ), right-click on “setup.exe”, select the “troubleshoot compatibility” tab, check the “Troubleshoot program” check box and then click “The program worked in earlier versions of Windows but won’t install or run now”. Then select “Windows Vista Service Pack 2”. Then click “Start” program. Now everything should work properly! It will install. But don’t reboot yet!
Now locate and explore the freshly installed folder in your program files directory – (probably C:\Program Files (x86)\Launch Manager or C:\Program Files\Launch Manager depending on if you are running 64-bit or 32-bit)
right-click on “LManager.exe”, select the “troubleshoot compatibility” tab, check the “Troubleshoot program” check box and then click “The program worked in earlier versions of Windows but won’t install or run now”. Then select “Windows Vista Service Pack 2”. Then click “Start” program. Now everything should work properly! It will install.
Reboot and enjoy properly synced volume, and fully functioning buttons.
1helpful
Sound touchpad frozen on mute acer aspire 6920G.
Remove the power cable and battery. Hold the Power button on lap for 60 seconds. Connect the Battery and power. Check whether this works or not. If NO give me the details of the system (which OS is using).
3helpful
The microphone in my acer 6920 is not working....
i know it sounds crazy .... but check whether you have connected the jack to mic port (usually the pink )....if it is ok...
next go to start | run | type "mmsys.cpl" it will bring you the audio options... go to voice option ..... choose your device.... and click the test hardware....
and also do not forget to check whether the main volume is on or not....
this should solve your problem
3helpful
2answers
Screen change for a acer aspire 6920g
http://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
27helpful
2answers
Download virtual surround sound drivers
i have the acer 6920g notebook and had windows 7 installed and cant get my virtual surround sound working can you give me any clues. thanks
Cinedash touchpad
Try taking the battery out for 10 seconds, put it back in and boot as normal.
Worked for me on my Aspire 6920G! I think it must be a power-ratio problem.
ACER ASPIRE 6920g dvd writer doesnt work
hi good day..
try to reformat and reprogram the laptop or check the dvd driver maybe some wires on it is loose go to the nearest computer shop to fix it.
2helpful
4answers
Acer aspire 6920
go into control pannel, blue tooth devices look through the fomats and if you have bloue tooth it will show up. set up and go. is it 6920G its there
Mouse and keypad don't work in Acer aspire 6920G
It sounds like driver problem. You need to reinstall Windows.
4helpful
2answers
How to use the CineDashMediaConsole on a ACER Aspire 8920
Every now and then, the CineDash media console on the Aspire Gemstone Blue models freezes, turns off, refuses to work, leaves you in locked out of the car in the pouring rain… The causes are endless, but the solution is quite simple.
To reset the CineDash, remove the power cable AND the battery for more than ten seconds.
Tadaa!
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
