Hi, DLP Lamp has electrodes inside and ballast generates high voltage that makes spark on these electrodes thus got high bright light. New lamp wont die due to bad ballast so replace lamp and see tv works or not. This tv has self diagnostic feature, turn On tv and let it shut down, now check standby light that would be blinking in specific order, for example 3 or 4 times blink then pause for 3 seconds and again blinks. Let me know how many times standby light blinking in this tv to help you with more info. Thanks.
It is possible that the ballust assembly is causing the lamp to fail. You likely need to replaced the ballust with a new lamp because if the ballust is bad it has likely already damaged the lamp. If you have been handling the glass of the new lamps with your bare hands this could be the cause of the short lif as the oil from your hands will cause premature failure of the lamp.
