If the machine loads ups with water and does not stop then the water level sensor is fautly . But if the inlet valve stops on fill up but there is no spin of the motor or thereafter there is no spin/rinse or drain then the program controller / drain valve/pump must be checked.
<span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt">Hi,</span><br />
<span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"> </span><br />
<span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt">If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…</span><br />
<span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"> </span><br /><span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt; mso-ansi-language: EN-US; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><br />Washing Machine Problems No Water<br /><a href="http://www.fixya.com/support/r3880845-washing_machine_problems_no_water" target="_blank">http://www.fixya.com/support/r3880845-washing_machine_problems_no_water</a><br /><br />Washing Machine Fix Washing Machine No Water<br /><a href="http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no" target="_blank">http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no</a><br /><br />heatman101 <br style="mso-special-character: line-break" /><br style="mso-special-character: line-break" /></span>
Hello there : the Dreaded LF code means
LF
Long fill
If the water fill time exceeds ten minutes, the water valves are turned
off and "LF" is flashed.
Press STOP/CANCEL to clear the display. check the water controle inlet valves that are attached to the machine for proper operation and replace if found bad
