It's probably acting normal. Every camera (in one of the auto modes) must focus before it takes the image. In low light situations, or low contrast situations (white dog against a white background), many cameras have difficulty finding focus. This causes a delay before the shutter clicks. Try taking your camera out on a nice sunny day and take a pic. If there's no delay, there's your answer. If in a low light situation, click your flash on. That may help a bit to reduce the delay.
Are you saying that you're using a white background but it doesn't appear white in the pictures? If so, then yes, you need to change the white balance to match the light. Probably "tungsten" but you could try different settings and pick the one you like best or you could use a white piece of paper and set a manual white balance.
By using the manual white balance adjustment on most cameras, you can "filter" out the yellowish color cast you are experiencing. The adjustment is best made while standing in the area in which you will be shooting. You will see the shift in color on the camera's LCD as you switch from setting to setting. On most cameras adjustment to white balance requires you to take the camera off it's fully automatic setting.
The best setting really depends on the type of pictures you want. Do you want a white background and a completely focused picture or do you want a natural background and more artistic type of picture? The latter is easier to produce as it can be done with a soft hand-held flash and almost any kind of natural lighting conditions and you can put it on a surface according to what you want to get - reflection, colors, shadows and what not. Getting a white background takes more lighting effort and way more Photoshop to cut the item from the background. See the picture of the same rings, different style of photography.
Check the white balance setting of the camera. As you have a yellow cast, it could be because you are using it in Fluorescent (or Tubelight) setting. Changing this to Auto should solve this problem.
Have you tried setting the white balance to match your indoor lighting condtions (flourescent or incandescent indoor lighting)? If not, try it. You didn't mention what model camera you have, but look in your manual. It should mention how to adjust white balance.
aiya, sameish thing happened to me. i have the olympus FE230.. and i actually dropped it on the wood floor, so whenever i turn on the camera light is red, and the lcd is white. i can still take pictures though...
Try using the mode that shows the icon of the flower, it is for close-ups. Also try using bright desk lamps to illuminate the jewelry well enough so that a flash is not needed. if you can, set up a white box or white posterboard to bounce light around, this too will help. Placing the camera on a tripod or something to steady it while shooting will help as well.
