Yes, it could be.also may be build up of waste,(hair,etc) is the rest of bath room performing ok,has this problem just appeared ?just something's to look into
you have to access the lower control the switch should be an air type one it uses air pressure from pushing in the button they some times crack ,dislodge or damaged and will not turn on or off unit also switch can fail
Chances are that the drain assembly was not part of the tub but a 'generic' plumbing part. Is this pop up drain the type that you push down and it clicks closed and push down and then it pops up? It unscrews from the drain fitting and you can get a replacement at a big box store. A better pop up replacement is one called a Rapid-fit. It drains faster.
I take it that you removed the drain trip linkage and stopper through the vent hole .
You must now run a small hand or small power snake the less than eight feet to open the drain.
You can also plug up the vent,tightly and try a flat plunger on the tub drain .
