The camera works fine, but I recently purchased an iMac PC. The included program iMovie does not seem to be compatible with my NV-DS33. When I input from camera to PC, the movie gets broken up into 4 second clips. The problem is intermittant also, (sometimes it's OK & sometimes it's not). I have tried with a later model of Panasonic Camcorder, & that works OK. I have tried changing every setting I can think of on the Camera without success. Can you help
SOURCE: downloading video files from Hitachi camcorder hard drive to imac
The best way is to download a file converter and convert the files from the Hitachi hard drive to MOV format. I used an AVS converter to do this.
SOURCE: SOFTWARE PROBLEM
HAVE YOU TRIED THE CAMCORDER WEBSITE FOR UPDATED SOFTWARE? THEY MY HELP. SOME OF THE NEWER PHOTO PROGRAMS HAVE GOOD CAMERA RECOGNATION HARDWARE THAT MAY RECOGNIZE YOUR CAMERA TO DOWNLOAD. WINDOWS PHOTO GALLERY AND GOOGLES PICASA ARE TWO THAT MAY WORK FOR YOU. TRY THESE TO SEE IF THEY WORK. YOUR CAMCORDER MAY HAVE UPDATED SOFTWARE SINCE VISTA HAS BEEN OUT FOR A WHILE NOW. I WOULD START THERE. HOPE THIS HELPS. IF YOU NEED MORE HELP JUST REPLY TO
ARCLIGHT1217
SOURCE: driver needed for panasonic nv md9000 camera
Helloooooo, I bought a panasonic nv md9000 camcorder, but didnt got
drivers, now I cant connect it to My pc, from where I can get its
drivers please help me!
it hasn't to connect to the pc.
SOURCE: Is there a compatibility problem with Everio camcorder & iMacs?
How to convert .MOD file to mpg, avi, wmv,mp4,flv,mov,mkv and other common video formats?
if you got a JVC camcorder, or Panasonic camcorder or Canon MOD camcorder,you would have problably encountered such issue--- what to do with the MOD/TOD files? And you want to convert the recorded .MOD file type to mpeg, avi, mkv, flv, mp4, wmv or whatever more common, so that you can put them on Youtube, Myspace, Yahoo video, Metacafe? the problem is most major video editing suites seem to unwillingly accept the MOD/TOD format.
Someone successfully made it simply by changing the extension from .mod to mpg, but for most people, they just failed only to find there is no audio after the extension is changed, or the changed one doesn’t allow you to import these files into Windows movie maker, not to mention upload some video to Youtube.com or Facebook. People use different operation system, windows xp, Vista or else. No one wants to say they just want to enjoy the .mod files on camcorder
Stop wasting your time and getting pissed off. There is a very simple program that convert .mod NOT ONLY to mpg but many others like avi, mkv, flv, mp4, wmv, rm, rmvd, mov, dv, mg2 and swf. MOD converter is the one shoot all the trouble. This excellent mod conversion tool is not just a converter but also a video editing tool. From now on, with the MOD converter, you can enjoy your mod video on many media player, even on portable devices like blackberry, Gphone, PSP, Creative Zen,etc.
Things will be easier if you take a moment to finish reading the Step by Step on how to convert .mod to mpg, avi, wmv and others
Step by Step
How to convert .mod to mpg, avi, wmv and others?
Step1 Turn on your pc. Download and install MOD converter
Click here to download and install it by running iOrgsoftTODconverter.exe
Step 2: Turn on your camcorder and connect it to pc. Import the .MOD file onto PC.
Run MOD converter; select the .MOD file you want to convert by clicking the Add or File button to load MOD info. Click the profile button to define the output video format.
Step 3: click the Edit button to set detailed info for the desired video.
A. Click the Trim button to set the length/range of the video that need to be converted.
You can choose a part of a MOD or the whole one to convert
B. Click the Effect button to tune the saturation, contrast, brightness values and make sure are the one you preferred, preview the change on the screen.
C. Click the Crop button to cut the unnecessary part or black part of the movie.
D. Select .AVI or .MPG and select the directory that you’d like your file stored to.
Step 4: Convert video
After all settings is done. You are ready to start conversion. This step will take you a while to carry out the conversion process, the time vary with different parameters you set.
MOD converter is a package tool, whcih actually includes mod to mpg mod to mp4 mod to avi mod to wmv, mod to 3gp mod to mov mod to ipod mod to iphone mod to psp mod to iriver mod to creative zen mod to apple tv mod to blackberry mod to zune and one more TOD converter
SOURCE: HF10 camcorder cannot read some .mts files
My knowledge in video editing is limited, but here's what I could dig up.
m2ts is also referred to as AVCHD, (MPEG4) a high-def Interlaced format which most computers cant render properly since most computers render in progressive format. You have to convert it to MPEG2, AVI, WMV, MOV or other movie file types in Progressive mode, a process known as "Deinterlacing" in order to edit it. Depending on how big the file is and how fast your computer is this could take several hours. Also, you cant view AVCHD files on normal televisions, you need a high-def TV.
If you want to edit high-def videos with post-effects and music etc, for dvd or blue-ray, you'll need a more powerful computer. The "recommended" minimum is a 64bit dual core processor, windows vista 64 bit, a seperate 500Gb or bigger hard drive and at minimum, 3-4Gbs of RAM with a high-def TV monitor. (1080i) Rendering High-Def videos is process heavy and can take up to 12+ hours to render a single 30-60 minute video with post-fx like music, logo's etc. The reason you need a 64bit processor and 64bit windows is because regular XP and Vista wont recognize more than 3Gb of RAM.
You could get by with a 32bit dual core processor and 2 gigs of RAM on windows XP, it's just going to be slower. You will still probably need a high def monitor if your going to edit in high-def mode.
High-def is new technology to mainstream consumers. Supporting technology hasnt caught up yet including most software--however most of what I read stated that Sony Vegas Platinum can do this pretty well.
Your camera is capeable of recording in progressive mode. You'll have to read the manual on how to do this. This will record it in standard mode which is not high-def. (For future reference)
To sum it all up, the camera's technology is more advanced than most PCs. I downloaded AVS Video Converter and converted the AVCHD, (MPEG4) a high-def Interlaced format to HD Video 720p: WMV9, 7000 kbps....... on the drop down screen of the AVS program. I now can view my videos in Progressive Standard mode with NO choppy play back or problems. Please note that 720p is a non digital standard Television view.
Remember M2ts files need to be converted to Progressive non HD files so your computer can read them. That will stop the choppy skips.
Hope this helps.
