My problem is:
I am trying to make copies in my brother machine DCP 7020 and it's not working at all. The message is: "unable to print. Trobleshooting and routine maintenance. " I did the routine maintenance folowing the user guide but the problem insist. What else can i do?
SOURCE: Unable to clean
you need a new waist ink absorber box and have to do a reset. The absorber box can be purgchased from a service partner (see brother homepage of your country). Same procedure:
http://www.fixya.com/support/t139675-need_reset_purge_counter_due_error_46
SOURCE: Brother Model DCP-117C Printer -
you need a new ink absorber box which you can buy from a brother service dealer near your home (see brother homepage of your country). when done so open printer:
http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c
(use google translation german)
you have to rest the eeprom parameter, too
press menu then start bk-copy then fourtimes arrow-up quickly after another. machine will switch to maintenance mode. press by help of arrow up and set : 8 - 0. press start bk-copy til PURGE 64xx appears. press the sequence of 2 -7 -6 -3 (arrow up and set). PURGE will reset to 0000. press 9 - 9 to leave maintenance.
SOURCE: Brother MFC 210 C.
I have the same problem and have no idea how to fix it. I tried pressing the menu button, then black start and then up arrow 4x but this just tells me that there is a machine error and doesn't give an error code. There's a bunch of maintenance codes I can type in but I have no idea what will fix the problem. I tried pushing all numbers from 1 to 99 and nothing helped. Anyone know what's wrong?
There is no error code.
Does the printer give you an error code?
