The volume control on my new iPod Nano isn't working
The volume control on my new iPod Nano only works with the ear phones disconnected. With them connected the volume stays the same regardless of the volume setting.
Re: The volume control on my new iPod Nano isn't working
The iPod Nano has the ability to "lock" the volume of music played at a particular level. Perhaps this only affects the volume of the earphones (versus the internal speaker). Please see "Setting The Maximum Volume Limit" in the user's manual:
Resetting the volume limit on your iPod Nano affects everything you listen to, from music to audio books. You can adjust the volume for each individual item on your Nano using the click wheel, but the highs and lows of the sound will depend on the overall volume limit setting. Volume levels will vary with different ear buds and headphones, and using external devices like docking stations to play your iPod Nano will also cause variation in the volume.
Instruction:
1 Press any button on your iPod Nano's click wheel and turn it on. Press the "menu" button at the top of the click wheel until you reach the iPod menu. 2 Select "Settings" from this menu by scrolling down until "Settings" is highlighted, then click the center button. 3 Select "Playback" from the menu choices that show up.
4 Select "Volume Limits." You will reach a screen with a speaker icon and dots indicating the level of volume your iPod is currently set on. 5 Scroll the wheel up or back to adjust the volume limits. Press the center button and you will have the option to lock in your settings by selecting a four-digit combination lock. This is not a necessary step; you can click on "done" and finish. Setting the combination allows you to have more control over any future changes to your iPod's volume limits. Scroll the click wheel to select your combination. Press the center button and you will revisit the volume limits; adjust it as you like and press the center button.
How to Reset the Volume Limit on the iPod Nano Resetting the volume limit on your iPod Nano affects everything you listen to, from music to audio books. You can adjust the volume for each individual item on your Nano using the click wheel, but the highs and lows of the sound will depend on the overall volume limit setting. Volume levels will vary with different ear buds and headphones, and using external devices like docking stations to play your iPod Nano will also cause variation in the volume. Instructions 1 Press any button on your iPod Nano's click wheel and turn it on. Press the "menu" button at the top of the click wheel until you reach the iPod menu. 2 Select "Settings" from this menu by scrolling down until "Settings" is highlighted, then click the center button. 3 Select "Playback" from the menu choices that show up. 4 Select "Volume Limits." You will reach a screen with a speaker icon and dots indicating the level of volume your iPod is currently set on. 5 Scroll the wheel up or back to adjust the volume limits. Press the center button and you will have the option to lock in your settings by selecting a four-digit combination lock. This is not a necessary step; you can click on "done" and finish. Setting the combination allows you to have more control over any future changes to your iPod's volume limits. Scroll the click wheel to select your combination. Press the center button and you will revisit the volume limits; adjust it as you like and press the center button.
Tips & Warnings If you set up a combination and forget it, you can reset your iPod Nano and start over again. Resetting will not lose any of your downloads, but you will need to restore or reset many of the settings you initially chose when you first set up your iPod. Changing the volume limits on your iPod Nano covers everything on your player, but the sound levels for songs, audio books and shows will vary based on how they were recorded.
i have the same problem with 5th gen nano and the D650. It pairs and i can use the controls but no sound comes to the headphones. I tried the headphones with the onboard bluetooth on my ipod touch and i had no problems. The problem only happens with the d650 and my nano. Someone has made this work im sure.
Most often, the ear phone might be the problem.try getting a new ear phone preferable, one from another manufacturer,if it does the same way, the problem will be from the earphone port.
If you're willing to take a risk.... theres rockbox.org download/install that. It will pump an extra 25% or more volume out.... But the layout is different and takes some getting used to...
also you can buy some better headphones... the kind that cover the whole ear and not those little ear bud things!
Check that the volume limiter is not engaged. You can find this under Settings>Volume Limit or similar.
or this may help:
http://docs.info.apple.com/article.html?artnum=303414
First make sure your hold switch isn't on. It's on the top or bottom and slides
back and forth. It needs to be switched to the left. Once it is to the
left, here's how you reset:
You can reset your ipod by holding down the menu and select (round
button in the center) buttons down for at least 10 seconds. You'll see
an apple logo flash, that's when you stop pressing the buttons. It will
shut off, then back on.
If that doesn't work, try a restore. This will return it go factory settings.
How to restore iPod
Ensure that you
have an active Internet connection as new versions of iTunes and iPod
Software may need to be downloaded to your computer.
Download and install the latest version of iTunes if you do not already have it installed.
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click
the Restore button. You will be prompted with one or more restore
options that may prompt iTunes to automatically download the latest
iPod Software. The 4 possible restore options are:
Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A
progress bar will appear on the computer screen indicating that the
first stage of the restore process has started. When this stage is
completed, iTunes will present one of two messages on screen with
instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During
the stage 2 of the restore process, the iPod will show an Apple logo as
well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After
stage 2 of the restore process is complete and the iPod is connected to
the computer, the iTunes Setup Assistant window will appear asking you
to name your iPod and choose your syncing preferences similar to when
you connected your iPod for the first time.
