Question about Zebra Z4Mplus Label Printer
PRINTS ON ONLY HALF OF THE LABEL - Zebra Z4Mplus Label Printer
    Scholar:
  • 97 Answers
If the printing clearly stops, then the maximum width setting of the printer is not set to the full 4 inches (104mm) of the printhead. Go into the setup mode on the printer and look for the setting called PRINT WIDTH and make sure it's set to 104mm or close to that. If printing is only half way across the label, it's because the width is set to something less than 104mm.
if the print fades away off the label, that is due to an imbalance in the pressure across the printhead.
Hope that helps !
Posted on Apr 06, 2010
6ya staff
SOURCE:
Not printing properly
Printhead should be cleaned with a 90% alcohol solution, however that should not cause blurry print. I've seen some labeling programs that will blur part of your label after the trial period has expired. I would check to see if this happens on test prints also. Do a test print by holding down the button on power up and letting it go after the first blink.
Jun 09, 2015 | Zebra GK420D Direct Thermal Label Printer
TLP 2844-Z prints half the label info on half the label
check the label megerments at driver, or reset printer to default settings. you can also print settings direcly from printer without connect with computer, if still doing than, its possible the printhead its faulty. but before replacet please run test after factory default. hope it helps. Paulo.
Mar 28, 2014 | Zebra TLP 2844-Z Thermal Label Printer
My zebra only prints the half top
Try recalibrating by holding down the button on powerup. When the label starts to move let go. After it prints the diag page hit the button once to take it out of "dump mode"
Dec 06, 2011 | Zebra TLP 2844-Z Thermal Label Printer
I have a Z4M plus and it only prints half of the label. One half is well printed and the other half is blank. please help
Clean the print head. If half has got gummy from labels, it will not be able to print. You will need to use a solvent for the gummy adhesive... possibly Toluol... HOWEVER be very careful to keep that off ANY plastic parts.
Nov 26, 2009 | Zebra Z4Mplus Label Printer
Only prints on bottom half of label.
Your scanner and thermal printer has got loose connection. Print head also may need cleaning by own system. try from the software.
JMC
Aug 12, 2009 | Dymo LabelWriter 330 Thermal Printer
Prints half of label
Restart your computer. Turn your printer off and back on again. Restart your software for printing lables. When updating the printer drivers, all software needs to be restarted to make sure that the form controls are working properly.
Oct 06, 2008 | Zebra Eltron LP 2824 Thermal Printer
Zebra Z4Mplus Label Printer Logo
1,271 people viewed this question
Top Zebra Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marvin
Marvin
Ekse
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
